[GeoNetwork-users] More on Feature Table Attributes
I recently received a request to add variables to the GN metadata records and so have been looking at using the 19110 feature catalogue template (GN 2.10). It looked like it would work however when I get more than 3 variables, the template no longer has the codelist section (label, code, definition) when I add an entity/member. Has anyone used this template and know how to resolve this? Is there something I need to tweak in a particular file somewhere?
Would it work to manually edit the xml with the additional codes and import it? If so, which stylesheet would I use?
Other thoughts or solutions would be appreciated.
In addition, I've seen the examples that others have done with feature catalogues for the public-facing view, but what I think would really help is if I could get an internal look (a screenshot even) of how the data was entered into GN - what fields/dropdowns were chosen, etc.
Kathy
Hi Kathy,
2016-01-06 21:19 GMT+01:00 Kathy Koch <kkoch@anonymised.com>:
Did you try to switch to full view - which should display all elements from
the standards.
You don't need any stylesheet if the XML is ISO19110.
HTH.
Francois
Kathy
GeoNetwork-users mailing list
Yes I was using full view. The first three variables look fine, try to enter a 4th and the codelist fields are not there. I think my strategy at this point is to just use the 19139 and add the variables in the data quality section.
Kathy
Sent: Tuesday, January 19, 2016 8:58 AM
To: Kathy Koch <kkoch@...1164...>
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] More on Feature Table Attributes
Hi Kathy,
2016-01-06 21:19 GMT+01:00 Kathy Koch <kkoch@...1164...<mailto:kkoch@…1164…>>:
Did you try to switch to full view - which should display all elements from the standards.
HTH.
Francois
Kathy
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
