Dear all,
I am using gn 3.0.4 and I need to move the database to another server (MS
SQL Server). I made an exact copy of the database and change the
sqlserver.xml to point the correct database and I got an error that this
doesn't match the svn subversion. Since I don't use versioning I deleted
the subversion folder and it got recreated automatically but then I get the
error:
svn: E160004: Found malformed header in revision file
What would be the best way to move my db to a new server?
Best,
Periklis
See
http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-x-et-port-postgresql-different-5432-td5274877.html
Drop metadata_subversion folder, by default in
WEB-INF/data/data/metadata_subversion
HTH.
Francois
2016-09-19 17:33 GMT+02:00 Periklis Panagiotidis <
periklis.panagiotidis@anonymised.com>:
Dear all,
error:
Best,
Periklis
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
