[GeoNetwork-users] Multinode and user accounts
I'm looking to configure a multinode instance of geonetwork. However, following the documentation seems to result in a strange issue. When the new node is added it appears to still use the original database for storing and retrieving user accounts rather than the new database.
Steps to recreate:
1) Alter srv.xml to use a postgres database e.g localhost:5432/db1
2) Add a new node (node2) and point to an new database e.g. localhost:5432/db2
3) Log in to the new node as admin/admin and create a new user
The new user is being stored in db1.public.users rather than db2.public.users. Once created the user can't be edited when logged into node2, but is editable in the default node. Have I missed something in the config or is there an issue with the jdbc overides not being picked up for the user creation code?
I would have expected that user accounts would be completely separate between multinode instances.
Regards
David
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
The ultimate parent company of the Atkins Group is WS Atkins plc. Registered in England No. 1885586. Registered Office Woodcote Grove, Ashley Road, Epsom, Surrey KT18 5BW. A list of wholly owned Atkins Group companies registered in the United Kingdom and locations around the world can be found at http://www.atkinsglobal.com/site-services/group-company-registration-details
Consider the environment. Please don't print this e-mail unless you really need to.
