[GeoNetwork-users] Multinode Geonetwork
Hi Developers,
I'm testing Geonetwork 3.2.x, specifically in multinode format. I've
configured a second node using these instructions:
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/using-multinode-mode.html
I've done this manually (ie adding a node to WEB-INF/web.xml and a node in
config-node copied from the example xml in the link above), and also using
the shell script.
The second database (postgres) is populated on a tomcat restart and I can
visit the home page for the second node, which shows no metadata, as
expected. When I sign in I get the following error in the browser:
Raised exception while starting the application. Fix the error and restart.
Message
org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out:
NativeFSLock@/data/geonetwork/lucene_dir/taxonomy/write.lock
Handler
org.fao.geonet.Geonetwork
Exception
java.lang.RuntimeException:
Stack
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:124)
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.acquire(LuceneIndexLanguageTracker.java:187)
at
org.fao.geonet.kernel.search.SearchManager.getIndexReader(SearchManager.java:1210)
at
org.fao.geonet.kernel.search.SearchManager.getNewIndexReader(SearchManager.java:1215)
at
org.fao.geonet.kernel.search.SearchManager.getDocsChangeDate(SearchManager.java:945)
at org.fao.geonet.kernel.DataManager.init(DataManager.java:346)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:345)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:448)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:191)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:84)
at javax.servlet.GenericServlet.init(GenericServlet.java:158)
at
org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1238)
at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1151)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1038)
at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4997)
at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5289)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:939)
at
org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1812)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.lucene.store.LockObtainFailedException: Lock obtain
timed out: NativeFSLock@/data/geonetwork/lucene_dir/taxonomy/write.lock
at org.apache.lucene.store.Lock.obtain(Lock.java:89)
at org.apache.lucene.index.IndexWriter.<init>(IndexWriter.java:724)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.openIndexWriter(DirectoryTaxonomyWriter.java:265)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:192)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:315)
at
org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyWriter.<init>(DirectoryTaxonomyWriter.java:332)
at
org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.init(TaxonomyIndexTracker.java:69)
at
org.fao.geonet.kernel.search.index.TaxonomyIndexTracker.<init>(TaxonomyIndexTracker.java:63)
at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.lazyInit(LuceneIndexLanguageTracker.java:115)
... 26 more
This is also shown in catalina.out. At this point, the URL has dropped back
to the default node rather than the new node. At this point I can't sign in
to either node. I have tried renaming the lucene directory since that's
reported in the error message, and the only way I can sign in to the
default node is to remove the second node from config-node and restart. The
existing records get reindexed and everything works OK.
What else should I be doing to make this work?
Thanks
Jo
*Jo Cook*
t:+44 7930 524 155/twitter:@archaeogeek
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
<https://twitter.com/astuntech&gt;
iShare - enterprise geographic intelligence platform
<https://astuntechnology.com/ishare/&gt;
GeoServer, PostGIS and QGIS training
<https://astuntechnology.com/services/#training&gt;
Helpdesk and customer portal
<http://support.astuntechnology.com/support/login&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
