[GeoNetwork-users] Multinode mode - Geonetworkv3.0.0
I have two projects, so I'm interested in the multinode mode. I installed my
nodes by following the instructions :
http://docs.titellus.net/geonetwork/en/maintainer-guide/installing/using-multinode-mode.html?highlight=node
I added a new node, with a second database, and I have customized each node.
Now, I have two different interfaces with two data sources.
The first node works fine (défault node srv).
I have problems with the second : unable to upload data.
To import metadata -> I get errors of incorrect format (xml files detected
as MEF). There is the same error for zip files, or MEF files.
To import another type of data (like a new logo for example), I have an
upload error also.
Only the copy/paste import works.
I think, I have a problem with some paths
Does anyone has had this problem?
Regards.
log :
2015-06-16 10:00:50,119 WARN [geonetwork.data.directory] - - Data
directory provided could not be used. Using default location:
/usr/local/geonetwork/web/geonetwork/WEB-INF/data
2015-06-16 10:00:50,276 WARN [geonetwork.schemamanager] - Cannot resolve
http://www.w3.org/2001/03/xml.xsd: will append last component to current
path (not sure it will help though!)
2015-06-16 10:00:50,869 WARN [geonetwork.schemamanager] - WARNING:
gco:Record is a global element without a type - assuming a string
2015-06-16 10:00:50,895 WARN [geonetwork.schemamanager] - WARNING:
schema-substitutions.xml has wiped out XSD substitution list for
gml:CoordinateSystemAxis
2015-06-16 10:00:50,912 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalCS
2015-06-16 10:00:50,930 WARN [geonetwork.schemamanager] - WARNING:
gml:VerticalDatum
2015-06-16 10:00:52,443 WARN [geonetwork.schemamanager] - WARNING:
2015-06-16 10:00:54,779 WARN [geonetwork.lucene] - Stopwords file with
incorrect ISO 639-2 language as filename: README
2015-06-16 10:01:09,221 WARN [geonetwork.resources] - Resource not found,
default resource returned: /images/logos/favicon.png
2015-06-16 10:01:09,613 WARN [geonetwork.resources] - Resource not found,
2015-06-16 10:01:11,389 WARN
[org.springframework.context.support.ResourceBundleMessageSource] -
ResourceBundle [messages] not found for MessageSource: Can't find bundle for
base name messages, locale fre
2015-06-16 10:01:15,711 ERROR [jeeves.service] - Service not found : config
2015-06-16 10:02:25,773 WARN
base name messages, locale en_US
2015-06-16 10:02:27,334 ERROR [jeeves.service] - Service not found : config
2015-06-16 10:02:31,747 ERROR [jeeves.service] - Service not found : config
2015-06-16 10:03:22,824 ERROR [jeeves.service] - Exception when executing
service
2015-06-16 10:03:22,824 ERROR [jeeves.service] - (C) Exc :
MissingParameterEx : mefFile
2015-06-16 10:03:22,824 ERROR [jeeves] - Error occurred within a transaction
  at org.fao.geonet.Util.getParam(Util.java:74)
  at org.fao.geonet.services.mef.Import.serviceSpecificExec(Import.java:78)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multinode-mode-Geonetworkv3-0-0-tp5211169.html
