[GeoNetwork-users] multiple element bug
Hello.
Maybe I am wrong but I think I found a bug in Genetwork. When I tried to add
for example second element “Facsimile” or “Voice” there is a list of items
from which I can choose (list of roles [gmd:CI_RoleCode]). The same list
occurs in every element which I tried to add more then once. How can I add
any second element which will be a text field not list of items? Why all of
lists are the same?
Łukasz
View this message in context: http://www.nabble.com/multiple-element-bug-tf4265945s18419.html#a12140702
Sent from the geonetwork-users mailing list archive at Nabble.com.
Lukasz_Sobotowski wrote:
Hello.
lists are the same?
Łukasz
Hi Lukasz,
It's a bug due to some code for ISO19139 profiles that was inadvertently left in the editor code and which got sucked into the beta 5 release.
If you upgrade your source code from the svn by copying in:
src/org/fao/geonet/kernel/EditLib.java
and recompile the problem should be fixed and adding elements will work as expected.
Simon
Hello.
add
items
add
of
lists are the same?
Łukasz
Hi Lukasz,
as expected.
Simon
GeoNetwork-users mailing list
I did like You said and there are still bugs. When I tried to add once more
element which is a list of items it works correctly, but when I tried to add
element which is normal text field, new element is a list of items too. For
example when I tried to add once more “Voice” element or “Facsimile” then
the same list of items occurs again.
View this message in context: http://www.nabble.com/multiple-element-bug-tf4265945s18419.html#a12176656
