[GeoNetwork-users] Need Help to Use Login Service Via Java in GN2.10
Hello
I am using the below Sample Code in Java to test login to Geonetwork 2.10 from an external application and I always get Login Not Successful Message. Do I need to enable any other config for this to work. I have also tried with the url http://192.168.1.172:8081/geonetwork/srv/eng/j_spring_security_check and it did not work
.Any help is appreciated. Thanks.
import org.apache.commons.httpclient.HttpClient;
import org.apache.commons.httpclient.HttpStatus;
import org.apache.commons.httpclient.methods.PostMethod;
public class TestGNLogin {
  * @param args
public static void main(String args) {
  // TODO Auto-generated method stub
  try {
    HttpClient httpClient = new HttpClient();
    String url = "http://192.168.1.172:8081/geonetwork/j_spring_security_check";
    PostMethod post = new PostMethod(url);
      post.addParameter("username", "admin");
     post.addParameter("password", "admin");
            // Send login request**
            httpClient.executeMethod(post);
            if(post.getStatusCode() == HttpStatus.SC_OK) {
              post.releaseConnection();
                  System.out.println("Login Successful");
           } else {
                  System.out.println("Login Not Successful");
  } catch(Exception e) {
    e.printStackTrace();
Regards
Kumaran
Hi, in 2.10, I would recommend using Basic Authentication. Talend
Spatial is using it, it works well
https://github.com/talend-spatial/talend-spatial/blob/master/org.talend.libraries.sdi/src/main/java/org/talend/sdi/metadata/Catalogue.java#L111
and much simpler than using the login service.
HTH.
Francois
2013/7/12 Kumaran Narayanaswamy <kumaran@anonymised.com>:
Hello
it did not work
  * @param args
        try {
                String url =
"http://192.168.1.172:8081/geonetwork/j_spring_security_check&quot;;
           } else {
Regards
Kumaran
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Hello Francois
I tried with Basic Auth and I always get 403 Status and in Logs I see the following
2013-07-15 08:36:18,031 DEBUG [jeeves.config.springutil.GeonetworkFilterSecurity
Interceptor] - Secure object: FilterInvocation: URL: /srv/eng/j_spring_security_
check; Attributes: [denyAll]
Interceptor] - Previously Authenticated: org.springframework.security.authentica
tion.UsernamePasswordAuthenticationToken@anonymised.com: Principal: org.fao.geonet.ker
nel.security.GeonetworkUser@anonymised.com; Credentials: [PROTECTED]; Authenticated: tr
ue; Details: org.springframework.security.web.authentication.WebAuthenticationDe
tails@anonymised.com: RemoteIpAddress: 192.168.1.212; SessionId: null; Granted Authorities: R
egisteredUser, Guest, Editor, Reviewer, Monitor, Administrator, UserAdmin
I was thinking if it was with issue with war file and I downloaded the geonetwork.exe file and tested and got the same response.
Following is the code that I used
import org.apache.commons.codec.binary.Base64;
import org.apache.commons.httpclient.Credentials;
import org.apache.commons.httpclient.Header;
import org.apache.commons.httpclient.UsernamePasswordCredentials;
import org.apache.commons.httpclient.auth.AuthScope;
   * @param args
    try {
      String url = "http://192.168.1.172:8080/geonetwork/srv/eng/j_spring_security_check&quot;;
       // post.addParameter("username", "admin");
       //post.addParameter("password", "admin");
      //Credentials creds = new UsernamePasswordCredentials("admin", "admin");
      //httpClient.getState().setCredentials(AuthScope.ANY, creds);
       String user = "admin" + ":" + "admin";
             byte encoding = Base64.encodeBase64(user.getBytes());
             post.setRequestHeader(new Header("Authorization", "Basic " + new String(encoding)));
             post.setDoAuthentication( true );
           // httpClient.executeMethod(post);
           // System.out.println("Status Code :"+post.getStatusCode());
         int result = httpClient.executeMethod(post);
         System.out.println("result of Login is : "+result);
        String redirectLocation;
        Header locationHeader = post.getResponseHeader("location");
        System.out.println("locationHeader is : "+locationHeader);
        if (locationHeader != null) {
            redirectLocation = locationHeader.getValue();
            System.out.println("redirectLocation is : "+redirectLocation);
            post.setPath(redirectLocation);
        if (result == HttpStatus.SC_OK) {
           } else {
and the output I get is
result of Login is : 403
locationHeader is : null
Any Help is appreciated.
Regards
Kumaran
HTH.
Francois
Hello
it did not work
  * @param args
        try {
                String url =
           } else {
Regards
Kumaran
GeoNetwork-users mailing list
you don't need to access j_spring_security_check, simply connect to
the restricted access URL and BA will be checked when accessing the
page.
In your snippet, replace
by http://192.168.1.172:8080/geonetwork/srv/eng/admin
Cheers.
Francois
2013/7/15 Kumaran Narayanaswamy <kumaran@anonymised.com>:
Hello Francois
the following
org.fao.geonet.ker
Authenticated: tr
ue; Details:
Authorities: R
UserAdmin
         * @param args
                try {
                        String url =
"admin");
           } else {
Regards
Kumaran
HTH.
Francois
Hello
Successful
have
and
it did not work
  * @param args
        try {
                String url =
           } else {
Regards
Kumaran
AppDynamics
Thanks Francois that worked.
Regards
Kumaran
On 15-07-2013 17:20, Francois Prunayre wrote:
page.
Cheers.
Francois
Hello Francois
the following
org.fao.geonet.ker
Authenticated: tr
ue; Details:
Authorities: R
UserAdmin
         * @param args
                try {
                        String url =
"admin");
           } else {
Regards
Kumaran
HTH.
Francois
Hello
Successful
have
and
it did not work
  * @param args
        try {
                String url =
           } else {
Regards
Kumaran
AppDynamics
