[GeoNetwork-users] Newbie introduction and mapsearchproblems
I have found the bug related to the BBOX search failure.
Instructions:
- edit the file : web/xml/search/lucene.xsl
- remove line 126:
    <xsl:if test="$region">
- remove line 155:
    </xsl:if>
To perform a bbox query you have to:
- use the 'region' and 'relation' parameters
or
- use the 'relation', 'northBL', 'southBL', 'eastBL', 'westBL' parameters
Hi Andrea and Jeroen,
I'd like to introduce myself. I'm a software engineer of Oriol's work team
and I'm in charge of Marcoast Web Portal. Once I've read your reply I have a
question: So, Could you tell us which is the way to search by BBox please?
We've used Geonetwork 2.0.3 and introducing in the search request:
http://localhost:8080/geonetwork/srv/en/main.search?northBL=38.2&westBL=-17.
3&eastBL=51.1&southBL=-34.6&relation=equal
(These are exactly the coordinates of the bounding box of Africa)
It doesn't match with the expected sample metadata "Hidrological basins in
Africa".
Thanks a lot
Angel Zaballos
Software Engineer
GTD SISTEMAS DE INFORMACIÓN
Pg. Garcia Fària, 17
E-08005 Barcelona
www.gtd.es
Tel: +34 934 939 300
Fax: +34 932 255 080
angel.zaballos@anonymised.com
Este mensaje es confidencial. Cualquier distribución, uso o copia del
mensaje o de la información en el contenido por otras personas distintas de
los destinatarios esta prohibida. Si usted recibe este mensaje por error,
por favor comuníquemelo inmediatamente mediante reenvío del mensaje o por
otro medio.
This e-mail may be confidential. Any distribution, use or copying of this
e-mail or the information it contains by other than an intended recipient is
unauthorized. If you received this e-mail in error, please advise me (by
return e-mail or otherwise) immediately.
Ce courriel est confidentiel. Toute diffusion, utilisation ou copie de ce
message ou des renseignements qu'il contient par une personne autre que les
destinataires désignés est interdite. Si vous recevez ce courriel par
erreur, veuillez m'en aviser immédiatement, par retour de courriel ou par un
autre moyen.
-----Mensaje original-----
De: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] En nombre de Andrea
Carboni
Enviado el: lunes, 09 de octubre de 2006 15:41
Para: geonetwork-devel@lists.sourceforge.net
Asunto: Re: [GeoNetwork-devel] [SPAM] Newbie introduction and
mapsearchproblems
> We have download 2_0_FIX2 Geonetwork version as you suggested to us, but
> we’re still having the same problem with search by westBL, northBL. We
have
> built this version and installed the resulting geonetwork-2.0.3-install.
> However, when we introduce in the search request:
> http://localhost:8080/geonetwork/srv/en/main.search?region=338
<http://localhost:8080/geonetwork/srv/en/main.search?region=338&northBL=38.2
> &westBL=-17.3&eastBL=51.1&southBL=-34.6&relation=equal>
> &northBL=38.2&westBL=-17.3&eastBL=51.1&southBL=-34.6&relation=equal
> like FAO Web Site does:
> http://www.fao.org/geonetwork/srv/en/main.search?region=338
<http://www.fao.org/geonetwork/srv/en/main.search?region=338&northBL=38.2&we
> We don’t get any result. This request should match the sample product
> “Hidrological basins in Africa”. At the Fao Web Site the matching results
> seem OK.
I don't know what is going on the FAO site but you cannot search both a
region and a BBox.
opinions on IT & business topics through brief surveys -- and earn cash
GeoNetwork-devel mailing list
