We imported some metadata as template, then imported some medatada using
this template. Now when we view this metadata (inspire view) some attributes
(as seen in the attached image) are not in-line with their values. The
values are few lines below the attribute name. Why would this happen?
- there are a few line-breaks included in the value field of the metadata;
you can easily check that by editing the metadata;
- check the XSl for any line-breaks on that spot;
- perhaps you can play a bit with the CSS to align the value.
vRanger cuts backup time in half-while increasing security.
With the market-leading solution for virtual backup and recovery,
you get blazing-fast, flexible, and affordable data protection.
Download your free trial now. http://p.sf.net/sfu/quest-d2dcopy1
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
