[GeoNetwork-users] No data upload button after XML metadata import
Hi My name is Alan and I'm from the University of Auckland. Nice to meet you
all! :slight_smile:
Recently we are toying around with a standard setup of Geonetwork 2.2, and
it is all marvelous. However whenever we do an XML Metadata Insert, the
"Upload" button under distribution would not appear even when I change
Protocol under Online Resources to File for Download. As a result I had to
navigate to Advanced View and add an extra panel of Online Resources to get
the button back and upload the dataset.
Could anybody get me out of my misery on where the button went? :slight_smile:
Thanks!
Alan
View this message in context: http://n2.nabble.com/No-data-upload-button-after-XML-metadata-import-tp2411959p2411959.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Alan,
You have the option to change the XSL that is responsible for the transformation of the metadata. The other option you have is to use this tool to do an export of data + thumbnail + metadata and upload that straight into the geonetwork catalog.
Let me know if that works for you.
Ciao,
Jeroen
On Mar 4, 2009, at 12:53 AM, ache051 ache051 wrote:
Hi Jeroen!
Thanks for the help! The code works perfectly. The only thing would be that I export the XML from ArcGIS, would you know of a way to incorporate the XML element into the metadata schema, so I don't have to copy and paste it every time?
Thanks! :slight_smile:
Alan
2009/3/3 Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>
Hi Alan,
Welcome!
Try to make sure there's already the "template" online resource element in your XML you upload. That should hopefully give you your upload button immediately.
So it should look something like:
                                       <gmd:onLine>
                                               <gmd:CI_OnlineResource>
                                                       <gmd:linkage xmlns:srv="http://www.isotc211.org/2005/srv&quot;&gt;
                                                               <gmd:URL/>
                                                       </gmd:linkage>
                                                       <gmd:protocol>
                                                               <gco:CharacterString>WWW:DOWNLOAD-1.0-http--download</gco:CharacterString>
                                                       </gmd:protocol>
                                                       <gmd:name gco:nilReason="missing">
                                                               <gco:CharacterString/>
                                                       </gmd:name>
                                                       <gmd:description gco:nilReason="missing">
                                                       </gmd:description>
                                               </gmd:CI_OnlineResource>
                                       </gmd:onLine>
Ciao,
Jeroen
all! :slight_smile:
Thanks!
Alan
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
GeoNetwork-users mailing list
