Hello Jo, thanks for your help. I don't have a Geoserver and I tried to use
the NASA Earth Observations (NEO) WMS. I changed
the <mapSearch <mapViewer on config-gui.xml to this:
*<mapSearch options="{projection: 'EPSG:4326', maxExtent: new
OpenLayers.Bounds(-180,-90,180,90), units: 'degrees', restrictedExtent: new
OpenLayers.Bounds(-180,-90,180,90)}">*
* <layers>*
* <layer server="http://neowms.sci.gsfc.nasa.gov/wms/wms
<http://neowms.sci.gsfc.nasa.gov/wms/wms>? " tocName="NASA Earth
Observations (NEO) WMS" params="{layers: 'NASA Earth Observations (NEO)
WMS", transparent: 'true', format: 'image/jpeg'}" options="{isBaseLayer:
true}" />*
* </layers>*
* </mapSearch>*
* <mapViewer options="{projection: 'EPSG:4326', maxExtent: new
* <layers>*
<http://neowms.sci.gsfc.nasa.gov/wms/wms>?" tocName="NASA Earth
WMS', transparent: 'true', format: 'image/png'}" options="{}" />*
* <scales values="[7500000, 5000000, 2500000, 1000000, 750000, 500000,
250000, 100000, 75000, 50000, 25000, 10000, 7500, 5000, 2500, 1000]" />*
* <!--scales values="" /-->*
* <proj>*
* <crs code="EPSG:4326" default="1" name="WGS84 (lat/lon)" />*
* </proj>*
* <servers>*
* <server name="NASA JPL OneEarth Web Mapping Server (WMS)"
url="http://wms.jpl.nasa.gov/wms.cgi?" />*
* <server name="NASA Earth Observations (NEO) WMS"
url="http://neowms.sci.gsfc.nasa.gov/wms/wms
<http://neowms.sci.gsfc.nasa.gov/wms/wms>?" />*
* <server name="DEMIS World Map Server"
url="http://www2.demis.nl/mapserver/wms.asp
<http://www2.demis.nl/mapserver/wms.asp>?" />*
* <server name="Geoserver" url="http://localhost:8080/geoserver/wms
<http://localhost:8080/geoserver/wms>?" />*
* </servers>*
* </mapViewer>*
I restarted the Tomcat and now when I access the GN it keep saying that is
loading the Geonetwork opensource catalouge and nothing is display.
Any ideia? Am I adding the WMS as it supposed to be?
Natália
On Tue, Apr 28, 2015 at 6:34 AM, Jo Cook <jocook@anonymised.com> wrote:
Hi Natália,
Take a look at WEB-INF/config-gui.xml- at the mapSearch and mapViewer
sections. By default these are configured to point at a local installation
of Geoserver, so if you don't have that then no mapping will appear. You
can configure those sections to point at any WMS- you need to change the
server URL, possibly the map options (CRS, maxExtent, units) and definitely
the layers. You will need to restart Geonetwork for any changes to show.
I hope that helps,
Jo
On Tue, Apr 28, 2015 at 12:31 AM, Natalia Queiroz <queiroz.nati@anonymised.com>
wrote:
Hello,
I just finished installing GN 2.10.4 and there is no image in the overview
map in the upper left of main page. When I click on the Show map link
below
where the map should be, the map image is also missing.
I'm using tomcat 8 and it is running on 8080
GN is running on 8080
I tried to change the GN port to 8085 but sill having the same issues. Any
ideia about this problem?
Natália Oliveira
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
*Jo Cook*
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
t:+44 7930 524 155
iShare - Data integration and publishing platform
<http://www.isharemaps.com/>
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Natália Oliveira
