[GeoNetwork-users] (no subject)
Hi
I've recently started my own website and would like to add geonetworks
to my site. How do i get geonetworks to work on my website? My
webserver is IIS 7, but i installed geonetworks with its default
webserver.
Geonetworks seems to run from the "c:\program files" directory, which
is presenting a problem for me in the sense that my site runs from the
"c:\inetpub\wwwroot" and linking the two directories proved
unsuccessful so far.
Any ideas?
THanks
Hi
You can not run directly GeoNetwork in IIS, you need to run GeoNetwork in
jetty (by default) or configure it in tomcat and later in IIS use
isapi_redirect or tomcat connector to allow the integration.
Also is better to install GeoNetwork outside Program Files folder. This
folder has some permission restrictions, so i would recommend to install
GeoNetwork outside of it.
Jose GarcĂ­a
GeoCat bv
On Fri, Jan 14, 2011 at 4:57 AM, Leidago !Noabeb <leidago@anonymised.com>wrote:
Hi
webserver.
Any ideas?
THanks
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
