[GeoNetwork-users] (no subject)
Hi, gurus,
I am new to GeoNetwork. just install GeoNetwork on a Lunix Centos box, using MySQL db.
after starting GeoNetwork by running "start-geonetwork.sh", I went to http://localhost:8080/geonetwork/srv/eng/home. Unfortunately, I got the following error message in the browser.
Anyone could point me where to start and look for this problem?
Thank you very much.
############################ Error msg caught ###############
HTTP ERROR 503
Problem accessing /geonetwork/srv/eng/home. Reason:
org\.jdom\.input\.JDOMParseException: Error on line 228: The entity name must immediately follow the '&' in the entity reference\.
Caused by:
org.eclipse.jetty.servlet.ServletHolder$1: org.jdom.input.JDOMParseException: Error on line 228: The entity name must immediately follow the '&' in the entity reference.
at org.eclipse.jetty.servlet.ServletHolder.makeUnavailable(ServletHolder.java:445)
at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:491)
at org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:293)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:739)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:254)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:683)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:39)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:494)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:141)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:56)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:540)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:403)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:337)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:121)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:555)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:230)
at org.eclipse.jetty.util.component.AggregateLifeCycle.doStart(AggregateLifeCycle.java:81)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:58)
at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:96)
at org.eclipse.jetty.server.Server.doStart(Server.java:275)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1266)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1189)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:472)
at org.eclipse.jetty.start.Main.start(Main.java:620)
at org.eclipse.jetty.start.Main.main(Main.java:95)
Caused by: org.jdom.input.JDOMParseException: Error on line 228: The entity name must immediately follow the '&' in the entity reference.
