[GeoNetwork-users] OAI ListRecords temporal search
Using 2.6.4 via the OAI provider, a simple request like:
http://HOST/geonetwork/srv/en/oaipmh?verb=ListRecords&metadataPrefix=iso
19139
yields results as expected.
However, using the 'from' parameter:
http://HOST/geonetwork/srv/en/oaipmh?verb=ListRecords&from=1999-10-10&me
tadataPrefix=iso19139
...yields no results, however all our records were inserted yesterday
(with gmd:dateStamp of 2013-11-08T05:38:05).
Clients use the 'from' parameter in support of periodic synchronization.
Any idea what's going on here? What is OAI.ListRecords.from bound to
FYI we are bound to 2.6.4 and providing via OAI.
Thanks
..Tom
It does seem to be acting on the metadata date (creation/revision), but isn't
handling it properly.
Eg it is treating the 'from=[date]' search as a "match [date]" search (not
that OAI has such a thing!)
TEST*:
When I tried the following, it only retrieved records with a metadata date
of exactly 2010-08-26 (whereas the catalogue definitely had records that had
been revised in 2012).
http://[hostname]/geonetwork/srv/eng/oaipmh?verb=ListRecords&from=2010-08-26&until=2013-10-31&metadataPrefix=iso19139
(*Using an older version of GN, so it might be different in 2.10?)
View this message in context: http://osgeo-org.1560.x6.nabble.com/OAI-ListRecords-temporal-search-tp5088176p5088667.html
Hi
At least in 2.6.X, seem the from parameter in the query in used to query
the lucene fields tempExtentBegin and tempExtentEnd. It's not using the
gmd:dateStamp.
These fields use the information from the following metadata elements (you
can check further in the file index-fields.xsl):
   - gmd:identificationInfo/gmd:MD_DataIdentification/gmd:date/gmd:CI_Date
   gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod
At least in 2.6.X, seem not only matching the exact date. This is part of
the lucene query created, using an interval:
+(tempExtentBegin:[1999-10-10 TO *] tempExtentEnd:[1999-10-10 TO *])
I'm not an expert in OAI, if the metadata fields queried are not according
to the OAI specification, please open a bug in GitHub to be fixed in next
version.
Jose García
isn't
TEST*:
had
http://
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models.
Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and
register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
Hi: thanks for the info. After further investigation, per below, our metadata (WMO Core Metadata Profile 1.3) uses GML 3.2, which GN 2.6.4 does not recognize, which is why temporal searches were always empty.
Having said this, there is a bug in system configuration settings which does not allow me to set OAI Datesearch to "modification date" (keeps reverting to "temporal extent"). Fixing this manually under the hood fixes this.
Does latest stable GN support GML 3.2?
Thanks
..Tom
-----Original Message-----
Sent: 2013-11-12 02:37
To: kater2
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] OAI ListRecords temporal search
Hi
At least in 2.6.X, seem the from parameter in the query in used to query the
gmd:dateStamp.
Period
At least in 2.6.X, seem not only matching the exact date. This is part of the
I'm not an expert in OAI, if the metadata fields queried are not according to
the OAI specification, please open a bug in GitHub to be fixed in next version.
Jose García
> but isn't handling it properly.
> (not that OAI has such a thing!)
> TEST*:
> date of exactly 2010-08-26 (whereas the catalogue definitely had
> records that had been revised in 2012).
> http://
08-26&
> 5088176p5088667.html Sent from the GeoNetwork users mailing list
> -------- November Webinars for C, C++, Fortran Developers Accelerate
> Explore
> most from the latest Intel processors and coprocessors. See abstracts
> and register
> lktrk _______________________________________________
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/&gt;
for details. _________________________Jose GarcíaGeoCat
bvVeenderweg 13 6721 WD BennekomThe Netherlandshttp://GeoCat.net
<http://geocat.net/&gt; *
November Webinars for C, C++, Fortran Developers Accelerate application
performance with scalable programming models. Explore techniques for
threading, error checking, porting, and tuning. Get the most from the latest
Intel processors and coprocessors. See abstracts and register
trk
A few people have asked me to elaborate, so I'll do so on list:
1./
- system configuration update bug: when updating System Configuration in the UI from "temporal extent" (which is the default value GN deploys with) to "modification date", clicking "save", then restarting GN (as the docs say to do), the same setting is reverted back to "temporal extent". Even trying directly with the XML Services API yields the same result. The brute force fix is to shutdown GN, and update the value in your DB with:
update settings set value='2' where name='mdmode';
Alternatively, one can change the appropriate initial/default value in the db setup file https://github.com/geonetwork/core-geonetwork/blob/2.6.4/web/src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-default.sql#L8150
Having said this, I think "modification date" should be the default value (mdmode=2) given the nature of OAI-PMH and harvesting use cases seem to be (AFAICT) centred around synchronization as opposed to dataset temporal extent querying
2./
WMO 1.3/GML3.2: starting with GML 3.2, the GML namespace is version specific. I'm guessing GN is scanning for {http://www.opengis.net/gml\}TimePeriod type thing (as the namespace prefix resolves to the namespace URI), so for the OAI datesearch by temporal extent use case, this gets ignored. I'm not sure if this applies to all indexing of the metadata in GN.
From: Kralidis,Tom [Ontario] [mailto:Tom.Kralidis@…43…]
Sent: 2013-11-12 06:56
To: Jose Garcia; kater2
Thanks
..Tom
> From: Jose Garcia [mailto:jose.garcia@…444…]
> To: kater2
> Hi
> query the lucene fields tempExtentBegin and tempExtentEnd. It's not
> using the gmd:dateStamp.
> (you can check further in the file index-fields.xsl):
> Period
> of the lucene query created, using an interval:
> according to the OAI specification, please open a bug in GitHub to be fixed
in next version.
> Regards,
> Jose García
> > search (not that OAI has such a thing!)
> > TEST*:
> > metadata date of exactly 2010-08-26 (whereas the catalogue
> > definitely had records that had been revised in 2012).
> > http://
> 08-26&
> > tp 5088176p5088667.html Sent from the GeoNetwork users mailing list
> > Explore
> > the most from the latest Intel processors and coprocessors. See
> > .c lktrk _______________________________________________
> metadata on GeoServer and GeoNetwork. Visit http://geocat.net
> application performance with scalable programming models. Explore
> and register
> lk
> trk
trk
