Hi Hoddi
I looked at your GN3, your record is described using Dublin Core
standard and therefore some descriptions are missing (example URL download).
I think for a complete harvest you should use the EML standards from
GSIB. I think GN supports EML
http://osgeo-org.1560.x6.nabble.com/Add-schema-EML-on-geonetwork-td5172454.html
But not certain about harvesting. Can you try to set the harvest to use
EML instead of
metadataPrefix --> eml
Jorge
On 16-11-16 15:21, hoddih wrote:
Hello ......again.
I appreciate your help very much. Thanks for that.
I managed to harvest from GBIF to our Geonetwork using OAI protocol with
help from you and GBIF.
Result:
http://geo.abds.is/geonetwork/srv/eng/catalog.search#/search?resultType=details&sortBy=relevance&from=1&to=20&fast=index&_content_type=json&_cat=GBIF
The results is almost fine! There is a two think missing. If you open some
dataset.
1. The description for the datasets is missing
2. link to the original dataset. To GBIF etc.
About point 2 here above. There is a Identifier field that give a ID. Is it
possible to have it a link to gbif?
Example.
Geonetwork link to dataset harvested from GBIF:
http://geo.abds.is/geonetwork/srv/eng/catalog.search#/metadata/59876921-fda6-4fd5-af5d-cba2a7152527
Identifier 59876921-fda6-4fd5-af5d-cba2a7152527
If it can be changed to
http://www.gbif.org/dataset/59876921-fda6-4fd5-af5d-cba2a7152527 as a link!
If I download and look to the metadata the URL is there.
Best regards.
Hoddi
View this message in context: http://osgeo-org.1560.x6.nabble.com/OAI-PMH-Harvesting-result-tp5296061.html
GeoNetwork-users mailing list
ISRIC - World Soil Information
Post: PO box 353, 6700 AJ, Wageningen,
The Netherlands Visiting Address: Droevendaalsesteeg 3, 6708 PB
Wageningen (Bdg. 101),
Office: C.013
Office Phone: +31 (0) 317 4 83715
Mobile Phone: +31 (0) 613 9 06950
Skype: jorge.de.jesus (Jorge Samuel Mendes de Jesus)
OpenPGPKey: 0xA3D0065A
