[GeoNetwork-users] OGC filter "PropertyIsEqualTo" behaves more like "PropertyisLike", intended?
Hello
We are running a GN 3.6.0 instance with a Postgresql 10 dbs in a Windows
server environ* and are trying to make a csw:getRecords request with a
PropertyIsEqualTo filter return only exact matches:
*<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2
<http://www.opengis.net/cat/csw/2.0.2&gt;&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
service="CSW" version="2.0.2" resultType="results"
startPosition="1" maxRecords="15"
outputFormat="application/xml"
outputSchema="http://www.opengis.net/cat/csw/2.0.2
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance
<http://www.w3.org/2001/XMLSchema-instance&gt;&quot;
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd
<http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd&gt;&quot;
xmlns:gmd="http://www.isotc211.org/2005/gmd
<http://www.isotc211.org/2005/gmd&gt;&quot;
xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0
<http://www.opengis.net/cat/csw/apiso/1.0&gt;&quot;&gt; <csw:Query
typeNames="csw:Record">
<csw:ElementSetName>full</csw:ElementSetName> <csw:Constraint
version="1.1.0"> <ogc:Filter><ogc:PropertyIsEqualTo>
  <ogc:PropertyName>title</ogc:PropertyName>
<ogc:Literal>Cykelvägar</ogc:Literal>
</ogc:PropertyIsEqualTo></ogc:Filter> </csw:Constraint>
<ogc:SortBy xmlns:ogc="http://www.opengis.net/ogc
<http://www.opengis.net/ogc&gt;&quot;&gt; <ogc:SortProperty>
<ogc:SortOrder>ASCE</ogc:SortOrder> </ogc:SortProperty>
      </ogc:SortBy> </csw:Query> </csw:GetRecords*>
What this returns however is not only the metadata post with the exact
title "Cykelvägar" but rather every metadata post with titles matching
"*Cykelvägar*", of which there are three:
  *<csw:SearchResults numberOfRecordsMatched="3"
numberOfRecordsReturned="3" elementSet="full" nextRecord="0">*:
*<dc:title>Cykelvägar</dc:title>*
*<dc:title>Förslag cykelvägar (inkl. utgår) - ÖP 2030</dc:title>*
*<dc:title>Förslag cykelvägar - ÖP 2030</dc:title>*
As far as I'm aware PropertyIsLike allows wildcards and PropertyIsEqualTo
doesn't so it seems PropertyIsLike is supposed to return only exact
matches, is this correct?
If this is correct, how can we troubleshoot our current environment?
*The above request produces the same result on a default installation of GN
3.4 in a Linux environ (with the default h2 db)
Thanks for any replies /
David.
Hello David
I do not have a GeoNetwork 3.6 installlation ready to test it, but on 3.10 the following POST body works for me:
<?xml version="1.0"?>
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot;
                xmlns:gmd="http://www.isotc211.org/2005/gmd&quot;
                outputSchema="http://www.isotc211.org/2005/gmd&quot;&gt;
  <csw:Query typeNames="gmd:MD_Metadata">
    <csw:ElementName>
      /gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title
    </csw:ElementName>
    <csw:Constraint version="1.1.0">
      <Filter xmlns="http://www.opengis.net/ogc&quot;&gt;
        <PropertyIsEqualTo>
          <PropertyName>any</PropertyName>
          <Literal>Cykelvägar</Literal>
        </PropertyIsEqualTo>
      </Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
Best regards
Mit freundlichen Grüßen
Sven van Crombrugge
Sachgebiet 3.3 - Geoinformationssysteme, E-Government -
- Zentrale -
Von der Heydt 22 . 66115 Saarbrücken
Tel.: +49 (0) 681 9712-303 · Fax: +49 (0) 681 9712-200
S.vanCrombrugge@...1788... · www.lvgl.saarland.de
________________________________________________________________________________________________
Hinweis zum Datenschutz
Informationen über die Verarbeitung Ihrer personenbezogenen Daten gemäß Artikel 13 und Artikel 14 der
Verordnung (EU) 2016/679 (DSGVO) sind elektronisch auf unserer Internetseite abrufbar:
https://www.saarland.de/vermessung_geoinformation_landentwicklung.htm
unter der Rubrik: Hinweise zum Datenschutz
Von: David Persson <perssond9@...54...>
Gesendet: Donnerstag, 16. Juli 2020 10:46
An: GeoNetwork-users@lists.sourceforge.net
Betreff: [GeoNetwork-users] OGC filter "PropertyIsEqualTo" behaves more like "PropertyisLike", intended?
Hello
We are running a GN 3.6.0 instance with a Postgresql 10 dbs in a Windows server environ* and are trying to make a csw:getRecords request with a PropertyIsEqualTo filter return only exact matches:
What this returns however is not only the metadata post with the exact title "Cykelvägar" but rather every metadata post with titles matching "*Cykelvägar*", of which there are three:
*<dc:title>Förslag cykelvägar (inkl. utgår) - ÖP 2030</dc:title>* *<dc:title>Förslag cykelvägar - ÖP 2030</dc:title>*
As far as I'm aware PropertyIsLike allows wildcards and PropertyIsEqualTo doesn't so it seems PropertyIsLike is supposed to return only exact matches, is this correct?
David.
GeoNetwork-users mailing list
Thanks a lot! That made a difference!
David.
On Thu, Jul 16, 2020 at 11:28 AM van Crombrugge, Sven (LVGL) <
S.vanCrombrugge@anonymised.com> wrote:
Hello David
    <csw:ElementName>
    </csw:ElementName>
        <PropertyIsEqualTo>
      </Filter>
    </csw:Constraint>
  </csw:Query>
</csw:GetRecords>
Best regards
Sven van Crombrugge
- Zentrale -
S.vanCrombrugge@anonymised.com · www.lvgl.saarland.de
Von: David Persson <perssond9@anonymised.com>
Hello
David.
