Hello,
I create a metadata including 3 online ressource :
-Two Interactive map.
-And an URL link to download a dataset file.
When i use the search interface on the home page i find the metadata with
the button interactive map with the “+” option
The field expand, and i can see the two interactive map, very well.
But i also can see the online resource here.
Is it a bug ?
It will be better if only the interactive map appear here
I think the best way will be if the “interactive map” button only display
the interactive map resource, and the “download” button can also expand to
show all other online resource (not only the download file), and work also
with the URL link, maybe the button will be rename “online resource” ?
Like that the online resource and interactive map will be separate and all
accessible on the home search page.
What are you thinking about that ?
Fabien Bachraty
View this message in context: http://www.nabble.com/On-line-resource-and-interactive-map-tf4599122s18419.html#a13131008
Sent from the geonetwork-users mailing list archive at Nabble.com.
