[GeoNetwork-users] Online Resource problem when file uploading
Dear all,
I’m working with GeoNetwork 2.1 beta3 and I have a problem when I upload a
file to an Online Resource field of the Distribution section (gmd:online a
few levels below gmd:MD_Distribution) of the ISO19139. I have noticed that
this error occur with version beta4 and with ISO19115 template too. The
error is thrown when I browse for a local file and click on ‘upload’ button.
The strangest thing is that in version beta2 the error doesn’t occur but it
has another problem: when I upload the file Geonetwork put a default URL in
linkage field with the proper name of the file inside; the problem is that
this default URL begins with ‘http//localhost…’ (in fact something like
http://localhost:8080/geonetwork/srv/en/resources.get?id=
<http://localhost:8080/geonetwork/srv/en/resources.get?id=xx&fname=xxxx.yyy&
access=private> xx&fname=xxxx.yyy&access=private) so it implies that when a
client on a remote host wants to download the product he can’t due to the
wrong link pointing to a missing file on his ‘localhost’.
Does anyone know if there is a way to avoid this default ‘localhost’
pointing when uploading a file?
The stack trace of the error in last versions is the following:
HTTP ERROR: 400
Cannot build ServiceRequest
Cause : C:\Program
Error : java.io.FileNotFoundException
Stack :
java.io.FileNotFoundException: C:\Program
        at java.io.FileOutputStream.open(Native Method)
        at java.io.FileOutputStream.<init>(Unknown Source)
        at
org.apache.commons.fileupload.disk.DiskFileItem.write(DiskFileItem.java:423)
        at
jeeves.server.sources.ServiceRequestFactory.getMultipartParams(ServiceReques
tFactory.java:267)
        at
jeeves.server.sources.ServiceRequestFactory.extractParameters(ServiceRequest
Factory.java:214)
        at
jeeves.server.sources.ServiceRequestFactory.create(ServiceRequestFactory.jav
a:136)
        at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:146)
        at
jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:98)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:427)
        at
org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandl
er.java:473)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:568)
        at org.mortbay.http.HttpContext.handle(HttpContext.java:1565)
        at
org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext
.java:635)
        at org.mortbay.http.HttpContext.handle(HttpContext.java:1517)
        at org.mortbay.http.HttpServer.service(HttpServer.java:954)
        at org.mortbay.http.HttpConnection.service(HttpConnection.java:816)
        at
org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:983)
        at org.mortbay.http.HttpConnection.handle(HttpConnection.java:833)
        at
org.mortbay.http.SocketListener.handleConnection(SocketListener.java:244)
        at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357)
        at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534)
Thanks in advance.
Angel ZABALLOS
Project Engineer
GTD SISTEMAS DE INFORMACIÓN
Pg. Garcia Fària, 17 E-08005 Barcelona
Tel.: +34 934 939 300 Fax: +34 934 939 302
www.gtd.es - <mailto:angel.zaballos@anonymised.com> angel.zaballos@anonymised.com...
Este mensaje es confidencial. Cualquier distribución, uso o copia del
mensaje o de la información en el contenido por otras personas distintas de
los destinatarios esta prohibida. Si usted recibe este mensaje por error,
por favor comuníquemelo inmediatamente mediante reenvío del mensaje o por
otro medio.
This e-mail may be confidential. Any distribution, use or copying of this
e-mail or the information it contains by other than an intended recipient is
unauthorized. If you received this e-mail in error, please advise me (by
return e-mail or otherwise) immediately.
Ce courriel est confidentiel. Toute diffusion, utilisation ou copie de ce
message ou des renseignements qu'il contient par une personne autre que les
destinataires désignés est interdite. Si vous recevez ce courriel par
erreur, veuillez m'en aviser immédiatement, par retour de courriel ou par un
autre moyen.
(attachments)
Hi Angel,
there is a bug with file uploads and paths: it seems that some browsers put
a full path while others only the file name. I will fix it.
For the localhost problem, go to the config management page and change
the public host/port parameters.
Dear all,
HTTP ERROR: 400
Cause : C:\Program
Stack :
        at
        at
tFactory.java:267)
        at
Factory.java:214)
        at
a:136)
        at
        at
        at
        at
er.java:473)
        at
        at
.java:635)
        at
        at
Thanks in advance.
Angel ZABALLOS
Project Engineer
www.gtd.es - <mailto:angel.zaballos@anonymised.com> angel.zaballos@anonymised.com17...
otro medio.
autre moyen.
