[GeoNetwork-users] OpenSearch (and Liferay)
I'm looking into the possibility to integrate GN OpenSearch as an federated search in Liferay CMS.
Maybe you have tried this before or have some Java code for GN OpenSearch parsing.
The interface and uses of it:
http://docs.liferay.com/portal/6.1/javadocs-all/com/liferay/portal/kernel/search/class-use/OpenSearch.html
Article about federated search via OpenSearch++ in Liferay:
http://www.packtpub.com/article/employ-federated-opensearch-csz-maps-web-content
GN OpenSearch sample description (found by google):
http://cmgds.marine.usgs.gov/geonetwork/srv/en/portal.opensearch
kind regards
Jørn-Vegard Røsnes
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
