hello,
does someone use the opensearch (georss) interface? which kind of filter can
be defined? is there a documentation howto do spatial filtering? i think i
need some examples.
thanks and greetings
armin
Armin Retterath
Kompetenz- und Geschäftsstelle GDI-RP
beim LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Tel.: 0261/492-466
EMail: armin.retterath@anonymised.com
http://www.geoportal.rlp.de
Hello Armin,
Armin Retterath wrote:
hello,
need some examples.
The opensearch protocol is using the rss.search service in GeoNetwork.
rss.search?any={searchTerms}&bbox={geo:box?}
Here is the draft spec.
http://www.opensearch.org/Specifications/OpenSearch/Extensions/Geo/1.0/Draft_1
Ciao.
Francois
armin
hello francois,
thanks. i have some other questions:
is it possible to define the fields to be searched? in germany we use a
central catalogue for all environmental data (http://www.portalu.de). they
have an opensearch interface where you can define the topology of catalogues
as standard get parameters. you can define which harvested catalogue entries
should be in the response. on the other hand you can define filters on
different entries like categories and so on. i think is would be a good idea
if geonetwork would do a similar approach.
is there a possibility to do the search in the different search fields that
INSPIRE demands (over opensearch protocoll - not csw)?
thanks
armin
Am Montag 26 Januar 2009 23:04:25 schrieb Francois-Xavier Prunayre:
Hello Armin,
> hello,
> can be defined? is there a documentation howto do spatial filtering? i
> think i need some examples.The opensearch protocol is using the rss.search service in GeoNetwork.
rss.search?any={searchTerms}&bbox={geo:box?}Here is the draft spec.
t_1Ciao.
Francois> thanks and greetings
> armin
Armin Retterath
beim LVermGeo-RP
56073 Koblenz
Tel.: 0261/492-466
Hello Armin,
I guess it depends on the client. I only used firefox opensearch link to
do full text search. But you could use other search fields define in
Lucene index (any, themekey, title, abstract, ...)
HTH. Francois
in germany we use a
INSPIRE demands (over opensearch protocoll - not csw)?thanks
arminAm Montag 26 Januar 2009 23:04:25 schrieb Francois-Xavier Prunayre:
Hello Armin,
hello,
t_1Ciao.
Francoisthanks and greetings
armin
