[GeoNetwork-users] Optional non-empty elements - what do you think ?
hello lists,
I'd like your opinion about a change proposal suggested by someone in the
NGR project.
The situation as it is is:
1. a template contains optional elements
2. you create a metadata using the template
3. the editor presents the optional elements ("suggestions")
4. you do not fill out those optional elements
5. save the metadata
6. the editor saved the optional elements also
and voilà, the metadata just saved is invalid, if those optional elements
(or some descendant) cannot be empty.
Users can only prevent this by actively deleting suggested elements; the
problem with that is, that the vast majority of elements in e.g. ISO19139 is
optional. The user would spend more time deleting suggestions than actually
entering metadata content.
The poposed change is :
Do not save optional elements that cannot be empty and that were left empty
by the user.
It should greatly facilitate creating valid metadata using the GN editor. Of
course it should not apply to templates, only to metadata.
After discussing with Jeroen and Francois, it appears both don't like this
change and they prefer the status quo. As Jeroen feels that if we had this
change, the editor would be making decisions about what the user wants,
instead of leaving it up to the user.
One could say that that is a matter of perception -- you could also very
well say that the current behaviour to save suggested elements even if the
user did not take up the suggestion, amounts to making decisions for the
user.
So I would like to ask everyone, what is your opinion about this ?
Kind regards
Heikki Doeleman
Heikki/List
Yes, this is a tricky problem.
I agree with Francios/Jereon i.e we would guessing about what the users wanted. I believe it's up to the
organisation to have procedures in place to document what elements should be entered. Some way to remedy
this problem is to fill the template optional elements opened with sample or dummy values that way you will get less validation
errors if users forgot to fill in some elements.
Andrew
----- Original Message ----- From: "heikki" <tropicano@anonymised.com>
To: "Geonetwork Users" <geonetwork-users@lists.sourceforge.net>; <geonetwork-devel@lists.sourceforge.net>
Sent: Friday, September 25, 2009 10:12 PM
Subject: [GeoNetwork-users] Optional non-empty elements - what do you think ?
hello lists,
I'd like your opinion about a change proposal suggested by someone in theNGR project.
1. a template contains optional elements2. you create a metadata using the template3. the editor presents the optional elements ("suggestions")4. you do not fill out those optional elements5. save the metadata6. the editor saved the optional elements also
and voilà, the metadata just saved is invalid, if those optional elements(or some descendant) cannot be empty.
Users can only prevent this by actively deleting suggested elements; theproblem with that is, that the vast majority of elements in e.g. ISO19139 isoptional. The user would spend more time deleting suggestions than actuallyentering metadata content.
Do not save optional elements that cannot be empty and that were left emptyby the user.
It should greatly facilitate creating valid metadata using the GN editor. Ofcourse it should not apply to templates, only to metadata.
After discussing with Jeroen and Francois, it appears both don't like thischange and they prefer the status quo. As Jeroen feels that if we had thischange, the editor would be making decisions about what the user wants,instead of leaving it up to the user.
One could say that that is a matter of perception -- you could also verywell say that the current behaviour to save suggested elements even if theuser did not take up the suggestion, amounts to making decisions for theuser.
Kind regardsHeikki Doeleman------------------------------------------------------------------------------Come build with us! The BlackBerry&reg; Developer Conference in SF, CAis the only developer event you need to attend this year. Jumpstart yourdeveloping skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;http://p.sf.net/sfu/devconf_______________________________________________GeoNetwork-users mailing listGeoNetwork-users@anonymised.com://lists.sourceforge.net/lists/listinfo/geonetwork-usersGeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Lists,
I agree that the editor should not try to second-guess the user. But the problem is that this is in fact what the editor is doing *now*, and the proposal is actually that this should be removed.
The editor is creating optional elements which the user has not asked for, and so is making decisions for the user. And if the editor is creating *invalid* metadata which the user has not asked for, then it is making pretty poor decisions.
It is a fairly basic UI concept that an application should not have an invalid default value for a field (here e.g. empty date) if there is a sensible valid default value available (here: whole optional section empty).
The proposal is not that something which the user enters be changed to something else (as with the notorious Microsoft Word Auto-Corrupt function). It is about consistent and user-friendly handling of the situation when in a particular section the user enters nothing: in that case the editor should create nothing.
Stephen Poley
Van: awalsh [mailto:awalsh@anonymised.com]
Verzonden: ma 28-9-2009 1:31
Aan: tropicano@anonymised.com
CC: geonetwork-users@lists.sourceforge.net; geonetwork-devel@anonymised.comrge.net
Onderwerp: Re: [GeoNetwork-users] Optional non-empty elements - what do youthink ?
Heikki/List
Andrew
hello lists,
metadata.
Hi Stephen,
I would like to comment on that observation and try to explain the idea behind the suggested elements:
When you add an element to an ISO metadata document, often the first level element is the container of a collection of other elements. For example, when you add a new contact, the contact itself is only a parent element with no value in it. It requires a couple of child elements to be of any use. So what the suggested elements function does is to add a more complete structure to the metadata document. In this example it would be the elements for name, address, telephone number etcetera. Some of these elements indeed are empty but are required to be filled in when validating metadata.
If you decide to remove the suggested elements function, you require the user to start adding elements, child elements, child elements of child elements and so forth by hand. Not only is that much more work, it also requires that the user has a very deep insight in the XML structure of the ISO metadata standard. It just makes for a much more complex editor. Indeed, the user is in full control, but also is required to know extremely well what to do. In my opinion that is not the background you can expect the majority of users to have (I myself would never be able to properly figure out where important metadata elements are located within the XML structure without studying the XML Schema or the standard document).
For these reasons I happily defend the existence of the suggested elements functionality. We have had a concept implementation of XML sub templates in the past where a user would be able to select from a couple of different sets of suggested elements. For instance one that is suitable for vector property descriptions and one for gridded data descriptions. That would be something I could see to come back in. Something along those lines is also the already implemented (but to my knowledge not part of the trunk) function to store spatial reference systems or contact "sub-templates" in the system and allow the user to add one of those to a record.
My suggestion to Heikki for the empty elements that cause the metadata to be invalid is:
Provide the user with a function (through a checkbox for instance) that would explicitly remove the empty elements that cause the metadata to be invalid. This checkbox could be an option that is part of the validation functionality that is already present. It could warn the user that empty elements will be removed from the metadata upon execution. The user would now be able to make a deliberate choice to cleanup and make the record validate.
I consider such an option less intrusive and less of the kind of "We know what you want" type of behavior compared to an automatic cleanup procedure.
My 2 cents, ciao,
Jeroen
On Sep 28, 2009, at 10:45 AM, Stephen Poley wrote:
Lists,
Stephen Poley
CC: geonetwork-users@lists.sourceforge.net; geonetwork-devel@anonymised.comforge.net
Heikki/List
Andrew
hello lists,
metadata.
Best Open Source Mac Front-Ends 2024
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
hi Jeroen !
You slightly misrepresented the proposal here: the idea is not to "remove
the suggested elements function" at all. The user would not be required to
start adding elements.
The proposal is that "suggestions" are treated as such, not stored when the
user does not follow up on them. The proposal is *not* about removing the
"suggestions" altogether.
Kind regards
Heikki Doeleman
On Mon, Sep 28, 2009 at 6:21 PM, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com
wrote:
Hi Stephen,
to be invalid is:
procedure.
My 2 cents, ciao,
Jeroen
> Lists,
> section empty).
> Stephen Poley
> do youthink ?
> Heikki/List
> Andrew
> you think ?
>> hello lists,
>> in theNGR project.
>> metadata.
> your
> stay
> now&#33;
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
Hi Stephen,
I discussed this again in more detail with Heikki yesterday and now think I understand the confusion. I just wanted to once more emphasize that none of the editors (default nor advanced) to the best of my knowledge create unasked-for metadata by themselves. Instead:
- The advanced editor presents optional metadata elements without storing them in the metadata document unless a user clicked on the + sign next to it. It also presents elements already part of the current metadata, and these can not be distinguished from the optional ones not yet present in the metadata.
- The default editor presents only elements that are part of the current XML document, these could indeed be unused and thus invalidate the metadata. It should not present (unless I'm not aware of this) optional elements by itself and add them.
The differences between the two editors allow for the default view to remain relatively simple, while the advanced editor provides all flexibility to the user to extend the document according to the XSD schema.
Now, one thing that could from that perspective be improved is this:
The optional elements that now can only be seen in the advanced view could also be made visible in the default editor. That visualization could in fact be optional to avoid all users always see all these optional elements. I could see this take shape in the form of a CSS style that can be enabled/disabled within the default editor. As a consequence we could indeed also prevent ghost elements in the metadata record, since they are not required anymore to be part of a template in order to make them visible in the default view.
I hope my attempt to explain this is clear. If you have any questions/ comments I would like to hear them of course.
Ciao,
Jeroen
On Sep 29, 2009, at 11:08 AM, Stephen Poley wrote:
Heikki/Jeroen,
I'm just confirming Heikki's note here. Presenting suggestions is good; creating unasked-for metadata is not.
Stephen
Van: heikki [mailto:tropicano@anonymised.com]
Verzonden: ma 28-9-2009 18:29
Aan: Jeroen Ticheler
CC: Stephen Poley; geonetwork-users@lists.sourceforge.net
hi Jeroen !
You slightly misrepresented the proposal here: the idea is not to "remove the suggested elements function" at all. The user would not be required to start adding elements.
The proposal is that "suggestions" are treated as such, not stored when the user does not follow up on them. The proposal is *not* about removing the "suggestions" altogether.
Kind regards
Heikki Doeleman
On Mon, Sep 28, 2009 at 6:21 PM, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com..> wrote:
Hi Stephen,
to be invalid is:
procedure.
My 2 cents, ciao,
Jeroen
> Lists,
> section empty).
> Stephen Poley
> CC: geonetwork-users@lists.sourceforge.net; geonetwork-devel@anonymised.comceforge.net
> do youthink ?
> Heikki/List
> Andrew
> you think ?
>> hello lists,
>> in theNGR project.
>> metadata.
> your
> stay
> now&#33;
ATLIS ATLIS
PO Box 41 Kosterijland 78 Web: www.atlis.nl
3980 CA Bunnik 3981 AJ Bunnik E-mail: info@anonymised.com
Tel: +31 30 602 00 70 Fax: +31 30 602 00 80 KvK/C of C: 10148291
ATLIS hanteert een email disclaimer (v1.1) en algemene voorwaarden voor verkoop (FENIT 2003) en Inkoop (v2.1).
Een kopie is opvraagbaar via 030 6020070 of info@anonymised.com
ATLIS maintains an email disclaimer (v1.1) and general Sales conditions for sales (FENIT 2003) and Purchasing conditions (v2.1).
A copy can be obtained via +31 30 6020070 or info@anonymised.com
I am confused by the statement from Jeroen.
I am looking at the current default editor and as well as showing entry
fields for those elements present in the source xml template it also
shows optional metadata fields (with a [+]) for those that are in the
schema.
I would very much like to be able to not have these optional fields
showing on the simpler default editor and only have them on the advanced
editor.
Perhaps I am missing a setting or option that causes the optional fields
not to show on the default editor.
Thanks Andrew
Andrew Watkins
Systems Development Team Manager
National Institute Water & Atmospheric Research (NIWA).
On 9/30/2009 at 3:51 AM, in message
<43149D2E-7387-4D25-8BAA-88FD53C32AF5@anonymised.com>, Jeroen Ticheler
<Jeroen.Ticheler@anonymised.com> wrote:
Hi Stephen,
schema.
Ciao,
Jeroen
Heikki/Jeroen,
Stephen
do youthink ?
hi Jeroen !
Kind regards
Heikki Doeleman
> wrote:
Hi Stephen,
When you add an element to an ISO me> example, when you add a new contact, the contact itself is only a
to be invalid is:
procedure.
My 2 cents, ciao,
Jeroen
> Lists,
> section empty).
> Stephen Poley
> O> > do youthink ?
> Heikki/List
> Andrew
> you think ?
>> hello lists,
>> in theNGR project.
elements
>> metadata.
SF, CA
> your
> stay
> now&#33;
your
stay
now&#33;
http://so> 3980 CA Bunnik3981 AJ BunnikE-mail:info@anonymised.com
Tel: +31 30 602 00 70Fax: +31 30 602 00 80KvK/C of C:10148291
stay
now&#33;
NIWA is the trading name of the National Institute of Water &
Atmospheric Research Ltd.
