[GeoNetwork-users] Oracle database without Gast
Hi folks,
Well, given Gast is apparently out of the question with 2.6.0 I've
connected to my Oracle database directly from GeoNetwork. Unfortunately
this doesn't seem to work. Prior to this I was running this install with
the mckoi database, but have disabled it now.
The first time I run GeoNetwork, with a new, empty Oracle database, it
does create the table structure but there's absolutely no data in there,
not even the admin account (at least, I'm guessing there's supposed to be
data in the database - for example, I can't login as geonetwork admin, I
get the "null Exception" error). The user does have permission to insert
data (I tested it by manually inserting a row as the same user)
My geonetwork startup log has the following errors from the FIRST timeI
run it with a clean database:
2010-07-27 09:34:19,917 INFO [jeeves.apphand] - - Database connection
on jdbc:oracle:thin:@IP_ADDRESS:1521:gismeta ...
2010-07-27 09:34:19,980 INFO [jeeves.apphand] -
jdbc:oracle:thin:@IP_ADDRESS:1521:gismeta is an empry database (Metadata
table not found).
2010-07-27 09:34:22,757 ERROR [jeeves.engine] - Raised exception while
starting appl handler. Skipped.
2010-07-27 09:34:22,757 ERROR [jeeves.engine] - Handler :
org.fao.geonet.Geonetwork
2010-07-27 09:34:22,757 ERROR [jeeves.engine] - Exception :
java.sql.SQLException: ORA-03290: Invalid truncate command - missing
CLUSTER or TABLE keyword
2010-07-27 09:34:22,757 ERROR [jeeves.engine] - Message : ORA-03290:
Invalid truncate command - missing CLUSTER or TABLE keyword
2010-07-27 09:34:22,772 ERROR [jeeves.engine] - Stack :
        at
oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:331)
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:288)
        at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:745)
        at
oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:216)
        at
oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:966)
        at
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1170)
        at
oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3339)
        at
oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(OraclePreparedStatement.java:3423)
        at jeeves.resources.dbms.Dbms.execute(Dbms.java:263)
        at jeeves.resources.dbms.Dbms.execute(Dbms.java:239)
        at org.fao.geonet.lib.DbLib.runSQL(DbLib.java:216)
        at org.fao.geonet.lib.DbLib.insertData(DbLib.java:182)
        at org.fao.geonet.Geonetwork.initDatabase(Geonetwork.java:402)
        at org.fao.geonet.Geonetwork.start(Geonetwork.java:137)
        at
jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:429)
        at jeeves.server.JeevesEngine.init(JeevesEngine.java:148)
        at
jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:74)
        at javax.servlet.GenericServlet.init(GenericServlet.java:241)
        at
org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:431)
        at
org.mortbay.jetty.servlet.ServletHolder.doStart(ServletHolder.java:263)
        at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
        at
org.mortbay.jetty.servlet.ServletHandler.initialize(ServletHandler.java:643)
        at
org.mortbay.jetty.servlet.Context.startContext(Context.java:140)
        at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1234)
        at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
        at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:460)
        at
        at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
        at
        at
        at
        at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
        at org.mortbay.jetty.Server.doStart(Server.java:222)
        at
        at
org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:985)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.mortbay.start.Main.invokeMain(Main.java:194)
        at org.mortbay.start.Main.start(Main.java:523)
        at org.mortbay.start.Main.main(Main.java:119)
The SECOND time I run geonetwork (or any thereafter) it does find the new
database and attempts a "migration":
2010-07-27 09:41:30,195 INFO [jeeves.apphand] - - Migration ...
2010-07-27 09:41:30,195 DEBUG [jeeves.apphand] - Webapp
version:2.6.0 subversion:RC0
2010-07-27 09:41:30,195 DEBUG [jeeves.apphand] - Database
version:null subversion:null
2010-07-27 09:41:30,195 INFO [jeeves.apphand] - Migrating from null
to 2.6.0 (dbtype:oracle)...
2010-07-27 09:41:30,195 INFO [jeeves.apphand] - No migration task
found between webapp and database version.
      The system may be unstable or may failed to start if you try to run
      the current GeoNetwork 2.6.0 with an older database (ie. null
      ). Try to run the migration task manually on the current database
      before starting the application or start with a new empty database.
      Sample SQL scripts for migration could be found in
WEB-INF/sql/migrate folder.
After that, there's a bunch of gibberish in the log I won't paste here
unless someone wants it. Then there's an error at the bottom of the log
(Different from the first one) saying:
2010-07-27 09:41:32,375 ERROR [jeeves.engine] - Raised exception while
2010-07-27 09:41:32,375 ERROR [jeeves.engine] - Handler :
2010-07-27 09:41:32,375 ERROR [jeeves.engine] - Exception :
java.lang.NullPointerException
2010-07-27 09:41:32,375 ERROR [jeeves.engine] - Message : null
2010-07-27 09:41:32,375 ERROR [jeeves.engine] - Stack :
        at
org.fao.geonet.kernel.setting.SettingInfo.getLuceneIndexOptimizerSchedulerEnabled(SettingInfo.java:96)
        at
org.fao.geonet.kernel.search.SearchManager.<init>(SearchManager.java:221)
        at org.fao.geonet.Geonetwork.start(Geonetwork.java:212)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Can someone tell me what's going on here? How do I get GeoNetwork 2.6.0 to
work properly with a Oracle database?
Software: Oracle 10.2.0.4, GeoNetwork 2.6.0RC0, JRE 1.6.20, JDK 1.6.21
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jonathan
I commited a fix for the script that loads the data in Oracle. The TRUNCATE
syntax seemed not correct for Oracle as should be TRUNCATE TABLE.
Finally, TRUNCATE was replaced with DELETE commands, as TRUNCATE produces
error "ORA-2266 unique/primary keys in table referenced by enabled foreign
keys", if the table to truncate has foreign keys from another table (also if
the tables are empty)
You can update the script from SVN:
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-oracle.sql
<https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-oracle.sql&gt;and
copy to install
folder\geonetwork\WEB-INF\classes\setup\sql\data\data-db-oracle.sql to
replace the one provided in RC0.
Probably you'll need to remove all tables from geonetwork db so the setup is
executed when startup GN.
Jose Garcia
On Tue, Jul 27, 2010 at 10:52 AM, <jonathanmoules@anonymised.com>wrote:
Hi folks,
table not found).
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
Jonathan
The Palm PDK Hot Apps Program offers developers who use the
Plug-In Development Kit to bring their C/C++ apps to Palm for a share
of $1 Million in cash or HP Products. Visit us here for more details:
http://ad.doubleclick.net/clk;226879339;13503038;l?
http://clk.atdmt.com/CRS/go/247765532/direct/01/
GeoNetwork-users mailing list
Hi Jose,
Thanks a lot, I can confirm that fixed it and it works now.
Quick very-minor thing for you of no real import, in the related "error"
message:
"2010-07-27 17:15:04,687 INFO [jeeves.apphand] -
jdbc:oracle:thin:@IP_Address:1521:gismeta is an empry database (Metadata
table
not found)."
You've mis-spelt "empty". :wink:
Again thanks.
Jonathan
message:
table
not found)."
Fixed in trunk,
Committed revision 6306.
Thanks for feedback.
Mathieu
  I too would like to know how to configure GeoNetwork 2.6 RC0 for MySQL without using GAST.
Ciao, Wolfgang
_______________________________
Wolfgang Grunberg
Arizona Geological Survey
wgrunberg@anonymised.com
520-770-3500
On 7/27/2010 1:52 AM, jonathanmoules@anonymised.com wrote:
Hi folks,
table not found).
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
Jonathan
Hello Wolfgang,
You just need to configure your config.xml file in your WEB-INF directory to
enable MySQL connection and to set up your connection parameters. Do not
forget to disable the default resource also (e.g mckoi).
Then, start your application server (i.e. Tomcat, Jetty, ...).
Finally, your MySQL database will be automatically set up.
Mathieu
On Tue, Jul 27, 2010 at 6:40 PM, Wolfgang Grunberg <wgrunberg@anonymised.com>wrote:
without using GAST.
Ciao, Wolfgang
Wolfgang Grunberg
520-770-3500
> Hi folks,
> table not found).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Source)
null
run
database.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Source)
to
> Thanks,
> Jonathan
In furtherence to this new requirement for manual setting up, may I
suggest more consistency and clarity in the config.xml file where it comes
to the jdbc <url>?
At present the various default <url> lines look like this:
                <url>jdbc:mckoi://localhost:9157/</url>
                <url>jdbc:mysql://$WEBSERVER_HOST/geonetwork</url>
                <url>jdbc:oracle:thin:@IP:1521:fs</url>
                <url>jdbc:postgresql:geonetwork</url>
i.e. They all specify the IP address and port in a different manner and to
someone new to jdbc (i.e. myself) it's hard to know what part is what,
especially for postgre which isn't showing any connection details. May I
suggest the following instead:
<url>jdbc:mysql://localhost:3306/$DATABASE_NAME</url>
<url>jdbc:oracle:thin:localhost:1521:$SID</url>
<url>jdbc:postgresql:localhost:5432/$DATABASE_NAME</url>
This way all four database connection types are consistent in their
default setup, allowing the user to easily configure them. If you want to
use "geonetwork" rather than "$DATBASE_NAME/$SID", I'd suggest making it
clear somehow that that's the database name. I.e. either a comment to that
effect or use "geonetwork_database".
(Hint: if you are going to use the above, check them for accuracy; as
noted I am new to JDBC).
Jonathan
