I'm trying to hook up GeoNetwork to an Oracle database using gast, but I'm getting this error: ORA-00911: invalid character. I'm using a completely stock GeoNetwork 2.6.0RC2 instance. In gast, I fill in the Configuration -> DBMS information, then go to Database -> Setup, and click Setup. I see it creating all of the tables, and I verified that the tables are actually created in the db. But when it gets to "Filling database tables", that error is thrown. Any ideas?
Thanks for any help,
Ryan
I found the problem. Gast was trying to send the sql commands with semicolons on the end, which was causing the invalid character error. I'll submit a patch.
Ryan
This SF.net Dev2Dev email is sponsored by:
Show off your parallel programming skills.
Enter the Intel(R) Threading Challenge 2010.
http://p.sf.net/sfu/intel-thread-sfd
GeoNetwork-users mailing list
