Hi everyone,
Sorry if this has been asked/answered before...
We are installing several GeoNetwork nodes in different organizations providing metadata and services, and a number of 'facilitator' nodes with search and display capabilities, which use local GeoNetwork instances to harvest and then search the metadata from the data-providing organizations. These organizations would like their logo to be displayed in the search results at the facilitator nodes, so these are my specific questions (we are using GeoNetwork 2.1 at both the provider nodes and the facilitator nodes, and I'm using Windows in my tests for the facilitator node):
1. Do we only need to configure the logos in the facilitator nodes doing the harvesting (by specifying the logo to be assigned to metadata harvested to each providing node)? Is there an alternative in which the logos are configured at each metadata-providing node and then just harvested by the facilitator nodes?
2. The instructions I've found on the web to configure the logos (in the node doing the harvesting) mention a location to store the logos (web/images/logos) which I assume is (web/geonetwork/images/logos in my installation) and an XML file (web/xml/sources.xml), which I haven't found. Should I create the latter from scratch in web/geonetwork/xml, or has the location/name of the file changed in 2.1?
Thanks a lot for any help,
Salvador Bayarri
IVER
Este mensaje y sus archivos son confidenciales. No está permitida su reproducción o distribución sin la autorización expresa de "IVER TecnologÃas de la Información". Si usted no es el destinatario previsto, queda desautorizado cualquier uso, acceso o copia de este mensaje. Si ha recibido este mensaje por error, por favor bórrelo e infórmenos por esta misma vÃa.
