Hi Gaby,
I think there may be something wrong with your indexes. I can see metadata records in the recently updated list, but they don't show up when searching. Searching uses the Lucene indexes and these are automatically build if not available and will be maintained when updating or adding records. You may want to check if these have been updated recently, or otherwise remove them and restart the site so they will be rebuild. let me know if this is indeed the case? The Lucene index files are located in the ../web/WEB-INF/lucene/ folder. You can safely remove all the files within this folder.
Ciao,
Jeroen
Begin forwarded message:
On Jun 21, 2006, at 3:12 PM, Gaby van Wyk wrote:
Hi Jeroen
You may remember that I mailed you on the Geonetwork list about the CSIR's SDI?
Well we've done a bit of work already - have a look at it:
http://146.64.81.55:8080/geonetwork/srv/en/main.homeFor the rest, you are welcome to play around with the metadata already
loaded (some 3500 records).We are now busy setting up the SANS (South African National Standards)
implementation. Anyone interested in helping?Gaby
