I have a machine running OSGEOLIVE 6
Geoserver and most packages work without any issues but I can't get Geonetwork to run.
The ApplicationsGeoserversGeonetworkStart seems to work fine but then I get an unable to connect on localhost:8880/geonetworks/srv/en/main.home
The Geoserver is on localhost:8082 and I can login to it but can not get to the geonetwork home page.
Osgeo seems to have also installed tomcat in localhost8080 -i don't need this.
I tried the following as well
Install Geonetwork2.8 beta (same issue with login to the home page). When I try sh start-geonetwork.sh I get a rm/mv error (see http://gis.stackexchange.com/questions/50093/osgeo-live-geonetwork-install-issues)
Install 2.4 using git clone instructions from geonetwork-opensource.org/download.html but I can't run the final command. See above link.
From this forum I tried the suggestions in http://sourceforge.net/mailarchive/forum.php?thread_name=CAGt6bQ6PCZbO%3Ds4Y1Z4GGQY6GN0hXRXZ89LQBUC%2BUWqNWabFeQ%40mail.gmail.com&forum_name=geonetwork-users to try the process in http://trac.osgeo.org/geonetwork/wiki/HowToRunUnderTomcat . I got stuck at editing the xml files in Catalina -the geonetwork etc .xml files are not in the folder. I only see hostmanager.xml, manager.xml, petascope.xml, ROOT.xml and wss.xml
Any ideas? I just want to open geoserver and geonetwork (also postgis)
best,
George Corea
GIS Officer
Atherton Tablelands Geographic Information Services
Part of Tablelands Regional Council
Phone: 07 4091 8607 | Fax: 07 4091 7035
Email: georgec@...1212... | Website: www.atgis.com.au
8 Tolga Road Atherton | PO Box 573 Atherton QLD Australia 4883
Tablelands Regional Council Disclaimer
This message and any attachments may contain privileged and confidential information intended only for the use of the intended addressee(s). Any unauthorized use of this material is prohibited. If you received this message in error please notify the sender immediately, delete the message and destroy any printed or electronic copies. Opinions expressed in this e-mail are those of the sender and do not necessarily represent the views of the Tablelands Regional Council. Council does not accept any responsibility for the loss or damage that may result from reliance on, or the use of, any information contained in this e-mail or attachments.
We recommend that you scan this e-mail and any attachments for viruses before opening. This Council does not accept liability for any loss or damage incurred either directly or indirectly from opening this e-mail or any attachments to it.
