[GeoNetwork-users] other type of validation then xsd [SEC=UNCLASSIFIED]
Hi Lukasz,
I believe GeoNetwork can now use Schematron to validate rules such as you
want thanks to Simon Pigot and maybe others.
Australia has created some Schematron that is available from
http://asdd.ga.gov.au/profileinfo/ . There are three Schematron files. They
are available from the following hypertext links: "Validates many of the ISO
19115 constraints/conditions", "Validates codeList values against codeLists"
and "Checks that there is content in the fileIdentifier". I think that they
are self explanatory.
I hope that this helps.
John
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On
Behalf Of Lukasz_Sobotowski
Sent: Wednesday, 4 June 2008 8:42 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] other type of validation then xsd
I'm wondering if GN has some other type of validation (than
XSD) implemented. In my case I have some connections between
particular metadata elements for example some elements must
be filled only when oher element doesn't exist. Does GN take
in to consideration such situations?? If not, what would be
the easiest way to do this (using for example javastript or
working on xml files)??
Please help!! :slight_smile:
View this message in context:
http://www.nabble.com/other-type-of-validation-then-xsd-tp1764
3820p17643820.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-users mailing list
