Yep - however have you tried searching for and then selecting the metadata you wanted to transfer and using the 'New Owner' operation in 'Actions on selected set'? Its already in GN 2.4 so no need to add functions/change java.
It will transfer ownership to editors, user admins, content reviewers etc
It is also tolerant when operating on records that are not owned by the person doing the 'New owner' operation (it skips them) so your search can be quite loose. So for example to transfer records from one editor to another, you could just log in as the editor whose records you want to transfer, search for all records in the editors group and then select all records and do a 'New Owner' - only those records which are owned by that editor will be transferred to the new owner and ownerGroup.
This could be made a little more direct by adding some more search options to the 'Restrict To' box in the advanced search.
Let me know if I've misunderstood what you had in mind.
Simon
________________________________________
From: Jean Pommier (IGE) [jean.pommier@anonymised.com]
Sent: Tuesday, 11 August 2009 11:51 PM
To: Emmanuel BELO
Cc: geonetwork-users; geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] [GeoNetwork-users] ownership transfer
Hi Emmanuel,
Thanks. I just wonder if there was a reason why you can just transfer ownership to editors in gn 2.4 ? Whereas whichever role can create metadata, actually... It doesn't look very consistent to me.
Could it be possible to, at least, make it configurable for next geonetwork release ? I don't like much changing java source code if I can avoid it...
Jean
2009/8/11 Emmanuel BELO <emmanuel.belo@anonymised.com<mailto:emmanuel.belo@anonymised.com9…>>
Hi Jean,
one could use the development made in the geocat sandbox:
http://geonetwork.svn.sourceforge.net/geonetwork/?rev=4697&view=rev
Best regards,
Emmanuel
Jean Pommier (IGE) wrote:
Is it normal that you can only transfer metadata ownership to editors, and
not to reviewers or admins ?
I've noticed that on gn 2.4, and wonders if it is a bug or not. To me, it
looks a bit restrictive. I'd like to be able to transfer, if necessary,
ownership to, at least, reviewers...
Jean
N'imprimez ce message qu'en cas de nécessité. Soyons éco-responsables !
Donnez une nouvelle dimension à vos données…
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Port : +33 6 09 23 21 36
Skype : igejean
Information Géographique et Environnement
12 rue Arnaud Vidal
31000 Toulouse
France
Tel : +33 5 61 86 81 49
Fax : +33 5 61 86 09 23
Mail : contact@anonymised.com<mailto:contact@anonymised.com>
Site web : www.ige.fr<http://www.ige.fr> <http://wwww.ige.fr>
*L'actualité d'IGE sur RSS : *http://www.ige.fr/actualites/rss.php
*Localisez IGE dans WorldWind : *
worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comceforge.net>
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Camptocamp SA
Emmanuel BELO
PSE A
CH-1015 Lausanne
+41 21 619 10 25 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
