Hi Jose,
Sending file log full
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.get
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.full
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.latest.updated
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.featured
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.categories
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.sources
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : pdf.search
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : pdf.selection.search
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : pdf.present
2011-02-23 13:45:08,218 INFO [jeeves.engine] - Adding service : portal.sitemap
2011-02-23 13:45:08,250 INFO [jeeves.engine] - Loading : C:\Geotecnologias\geonetwork\web\geonetwork/WEB-INF/config-export.xml
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Initializing services...
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Adding service : dc.xml
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Adding service : fgdc.xml
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Adding service : iso19115to19139.xml
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Adding service : iso19139.xml
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Adding service : iso_arccatalog8.xml
2011-02-23 13:45:08,265 INFO [jeeves.engine] - Loading : C:\Geotecnologias\geonetwork\web\geonetwork/WEB-INF/config-test.xml
2011-02-23 13:45:08,312 INFO [jeeves.engine] - Initializing services...
2011-02-23 13:45:08,312 INFO [jeeves.engine] - Adding service : test.i18n
2011-02-23 13:45:08,312 INFO [jeeves.engine] - Adding service : test.i18n.xml
2011-02-23 13:45:08,312 INFO [jeeves.engine] - Adding service : test.csw
2011-02-23 13:45:08,312 INFO [jeeves.engine] - Loading : C:\Geotecnologias\geonetwork\web\geonetwork/WEB-INF/config-csw.xml
2011-02-23 13:45:08,343 INFO [jeeves.engine] - Loading : C:\Geotecnologias\geonetwork\web\geonetwork/WEB-INF/config-sru.xml
2011-02-23 13:45:08,343 INFO [jeeves.engine] - Initializing services...
2011-02-23 13:45:08,343 INFO [jeeves.engine] - Adding service : portal.sru
2011-02-23 13:45:08,421 INFO [jeeves.engine] - Initializing profiles...
2011-02-23 13:45:08,453 INFO [jeeves.engine] - Found handler : org.fao.geonet.Geonetwork
2011-02-23 13:45:08,562 INFO [jeeves.engine] - --- Starting handler --------------------------------------
2011-02-23 13:45:08,578 INFO [jeeves.apphand] - Initializing GeoNetwork 2.6.3.0 ...
2011-02-23 13:45:08,890 INFO [jeeves.apphand] - - Database connection on jdbc:postgis://localhost:5432/dbgeonetwork ...
2011-02-23 13:45:09,187 INFO [jeeves.apphand] - Found an existing GeoNetwork database.
2011-02-23 13:45:09,187 INFO [jeeves.apphand] - - Setting manager...
2011-02-23 13:45:09,359 INFO [jeeves.apphand] - - Migration ...
2011-02-23 13:45:09,359 DEBUG [jeeves.apphand] - Webapp version:2.6.3 subversion:0
2011-02-23 13:45:09,359 DEBUG [jeeves.apphand] - Database version:2.6.3 subversion:0
2011-02-23 13:45:09,359 INFO [jeeves.apphand] - Webapp version = Database version, no migration task to apply.
2011-02-23 13:45:09,359 INFO [jeeves.apphand] - - Thesaurus...
2011-02-23 13:45:10,328 INFO [jeeves.apphand] - - Z39.50...
2011-02-23 13:45:10,390 INFO [jeeves.apphand] - Repositories file built from template.
2011-02-23 13:45:12,078 DEBUG [org.jzkit.search.util.RecordBuilder.RecordBuilderService] - new RecordBuilderService
2011-02-23 13:45:12,093 DEBUG [org.jzkit.search.util.RecordBuilder.RecordBuilderService] - RecordBuilderService::init
2011-02-23 13:45:12,890 DEBUG [org.jzkit.z3950.server.Z3950Listener] - new Z3950Listener()
2011-02-23 13:45:12,906 DEBUG [org.jzkit.service.z3950server.JZKitBackend] - New JZKitBackend 22908277
2011-02-23 13:45:12,953 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - setApplicationContext...
2011-02-23 13:45:12,953 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Load config: /JZKitConfig.xml
2011-02-23 13:45:12,953 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Loading rules : jar:file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/lib/jzkit-service-3.r260.geonetwork.pa
tch.1.jar!/org/jzkit/configuration/provider/xml/DigesterRules.xml
2011-02-23 13:45:13,031 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Parsing config
2011-02-23 13:45:13,031 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - registerClasspathProfile : profiles/geo.xml (ctx=org.springframework.context.support.ClassPathXmlApplicationContext@
2798e7: display name [org.springframework.context.support.ClassPathXmlApplicationContext@anonymised.com]; startup date [Wed Feb 23 13:45:10 BRT 2011]; root of context hierarchy)
2011-02-23 13:45:13,031 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - processing config file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/classes/profiles/geo.xml
2011-02-23 13:45:13,156 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Register profile : org.jzkit.search.util.Profile.ProfileDBO@anonymised.com...
2011-02-23 13:45:13,156 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - registerClasspathQueryCrosswalk : crosswalks/QueryModel/gils.xml
2011-02-23 13:45:13,171 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - processing crosswalk file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/classes/crosswalks/QueryModel/gils.xm
l
2011-02-23 13:45:13,203 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - registerClasspathQueryCrosswalk : crosswalks/QueryModel/dc.xml
2011-02-23 13:45:13,203 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - processing crosswalk file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/classes/crosswalks/QueryModel/dc.xml
2011-02-23 13:45:13,234 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - registerClasspathQueryCrosswalk : crosswalks/QueryModel/rec.xml
2011-02-23 13:45:13,234 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - processing crosswalk file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/classes/crosswalks/QueryModel/rec.xml
2011-02-23 13:45:13,234 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - registerClasspathQueryCrosswalk : crosswalks/QueryModel/geo.xml
2011-02-23 13:45:13,234 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - processing crosswalk file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/classes/crosswalks/QueryModel/geo.xml
2011-02-23 13:45:13,250 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - registerClasspathQueryCrosswalk : crosswalks/QueryModel/cql.xml
2011-02-23 13:45:13,250 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - processing crosswalk file:/C:/Geotecnologias/geonetwork/web/geonetwork/WEB-INF/classes/crosswalks/QueryModel/cql.xml
2011-02-23 13:45:13,265 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Calling register with xslt org.fao.geonet.services.util.z3950.transformers.GNTransformer
2011-02-23 13:45:13,265 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Calling register with xml::f -> html::f (xslt) = crosswalks/RecordModel/xml_to_html.xsl
2011-02-23 13:45:13,265 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection geonetwork
2011-02-23 13:45:13,265 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection applications
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service GN
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - applications
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - geonetwork
2011-02-23 13:45:13,281 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 150.229.226.17:6668/marlin
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service CSIROMAR
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 150.229.226.17:6668/marlin
2011-02-23 13:45:13,281 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.3.195.251:6668/nrdd
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service NSWRDD
2011-02-23 13:45:13,281 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.3.195.251:6668/nrdd
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 147.109.254.5:5550/tas
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service TSDD
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 147.109.254.5:5550/tas
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection data.aims.gov.au:5525/geonetwork
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service AIMS
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - data.aims.gov.au:5525/geonetwork
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 66.160.183.131:5511/act
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service ACT
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 66.160.183.131:5511/act
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.49.66.2:5550/product
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service AHS
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.49.66.2:5550/product
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 152.91.17.20:210/anrdl
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service BRS
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 152.91.17.20:210/anrdl
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 134.178.63.133:6668/bom_meta
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service BOM
2011-02-23 13:45:13,296 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 134.178.63.133:6668/bom_meta
2011-02-23 13:45:13,296 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 155.187.2.2:6668/edd
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service DIG
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 155.187.2.2:6668/edd
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 192.104.44.110:6668/ga
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service GA
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 192.104.44.110:6668/ga
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 66.160.183.131:6668/dataset
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service IndexGeo
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 66.160.183.131:6668/dataset
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 202.55.146.171:5548/mdbcprod
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service MDBC
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 202.55.146.171:5548/mdbcprod
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 150.229.226.17:6668/neptune
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service NOO
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 150.229.226.17:6668/neptune
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 150.191.80.24:210/NTSDD
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service NTSDD
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 150.191.80.24:210/NTSDD
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 202.161.118.130:210/PSMA
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service PSMA
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 202.161.118.130:210/PSMA
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.56.118.1:6668/qsiis_prod
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service QSIIS
2011-02-23 13:45:13,312 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.56.118.1:6668/qsiis_prod
2011-02-23 13:45:13,312 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.46.162.95:5550/qsii2
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service QSII2
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.46.162.95:5550/qsii2
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 59.154.117.67:5550/pages_xml
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service RANDOM
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 59.154.117.67:5550/pages_xml
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 143.216.198.138:6668/sa
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service SASID
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 143.216.198.138:6668/sa
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.11.140.26:6668/vicsdd
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service VSDD
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.11.140.26:6668/vicsdd
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.11.121.51:6668/airphoto
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.11.121.51:6668/biblio
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.11.121.51:6668/nrm
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.11.121.51:6668/eis
2011-02-23 13:45:13,328 DEBUG [org.jzkit.ServiceDirectory.SearchServiceDescriptionDBO] - add collection 203.11.121.51:6668/agency
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registering any collections from service WI
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.11.121.51:6668/nrm
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.11.121.51:6668/airphoto
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.11.121.51:6668/eis
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.11.121.51:6668/agency
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - - 203.11.121.51:6668/biblio
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Done Parsing config
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - -- initialising
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - -- Scanning classpath for jzkit backend plugins
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registered: JZKitZ3950PluginMetadata = org.jzkit.search.provider.z3950.JZKitZ3950PluginMetadata@anonymised.com
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - -- Scanning classpath for jzkit query builders
2011-02-23 13:45:13,328 DEBUG [org.jzkit.configuration.provider.xml.InMemoryImpl] - Registered QueryBuilder: QB-CQL = org.jzkit.search.util.QueryBuilder.CQLQueryBuilder@anonymised.com
2011-02-23 13:45:13,343 DEBUG [org.jzkit.search.util.RecordConversion.FragmentTransformerService] - new FragmentTransformerService
2011-02-23 13:45:13,359 DEBUG [org.jzkit.search.util.RecordConversion.FragmentTransformerService] - FragmentTransformerService::init
2011-02-23 13:45:13,359 DEBUG [org.jzkit.search.util.RecordConversion.FragmentTransformerService] - Register Type xslt class=org.fao.geonet.services.util.z3950.transformers.GNTransformer
2011-02-23 13:45:13,390 DEBUG [org.jzkit.search.util.RecordConversion.FragmentTransformerService] - from xml::f to html::f sheet=crosswalks/RecordModel/xml_to_html.xsl type=xslt
2011-02-23 13:45:13,406 DEBUG [org.jzkit.search.impl.StatelessQueryService] - new StatelessQueryService(50,180000)
2011-02-23 13:45:13,421 DEBUG [org.jzkit.search.impl.StatelessQueryService] - init()
2011-02-23 13:45:13,484 DEBUG [org.jzkit.search.util.RecordBuilder.RecordBuilderService] - onApplicationEvent org.springframework.context.event.ContextRefreshedEvent[source=org.springframework.context
.support.ClassPathXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.ClassPathXmlApplicationContext@anonymised.com]; startup date [Wed Feb 23 13:45:10 BRT 2011]; root of context h
ierarchy]
2011-02-23 13:45:13,484 INFO [jeeves.apphand] - Server is Enabled.
2011-02-23 13:45:13,500 INFO [jeeves.apphand] - - Search...
2011-02-23 13:45:13,500 DEBUG [org.jzkit.z3950.server.Z3950Listener] - Starting ZServer on port 2100 (timeout=300000)
2011-02-23 13:45:13,515 DEBUG [org.jzkit.z3950.server.Z3950Listener] - Waiting for connection
2011-02-23 13:45:14,046 INFO [jeeves.apphand] - NOTE: Using POSTGIS for spatial index
2011-02-23 13:45:17,890 INFO [jeeves.apphand] - - Access manager...
2011-02-23 13:45:17,937 INFO [jeeves.apphand] - - Data manager...
2011-02-23 13:45:18,171 INFO [jeeves.apphand] - Adding xml schema : csw-record
2011-02-23 13:45:18,734 INFO [jeeves.apphand] - Adding xml schema : dublin-core
2011-02-23 13:45:18,781 INFO [jeeves.apphand] - Adding xml schema : fgdc-std
2011-02-23 13:45:19,031 INFO [jeeves.apphand] - Adding xml schema : iso19110
WARNING: gco:Record is a global element without a type - assuming a string
2011-02-23 13:45:21,250 INFO [jeeves.apphand] - Adding xml schema : iso19115
2011-02-23 13:45:21,375 INFO [jeeves.apphand] - Adding xml schema : iso19139
WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:CoordinateSystemAxis
WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:VerticalCS
WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:VerticalDatum
2011-02-23 13:45:21,953 INFO [jeeves.apphand] - - Harvest manager...
2011-02-23 13:45:22,593 INFO [jeeves.apphand] - - Catalogue services for the web...
2011-02-23 13:45:23,187 INFO [jeeves.apphand] - - Open Archive Initiative (OAI-PMH) server: mode1 cachesize: 60 cachelifetime: 3600
2011-02-23 13:45:23,562 INFO [jeeves.apphand] - - Metadata notifier ...
2011-02-23 13:45:23,562 INFO [jeeves.apphand] - Site ID is : dummy
MetadataNotifierControl runOnce start
MetadataNotifierControl runOnce finish
2011-02-23 13:45:23,812 INFO [jeeves.engine] - --- Handler started ---------------------------------------
2011-02-23 13:45:23,812 INFO [jeeves.engine] - Starting schedule manager...
2011-02-23 13:45:23,812 INFO [jeeves.engine] - Memory used is : 16314 Kb
2011-02-23 13:45:23,812 INFO [jeeves.engine] - Total memory is : 506816 Kb
2011-02-23 13:45:23,812 INFO [jeeves.engine] - Startup time is : 20 (secs)
2011-02-23 13:45:23,812 INFO [jeeves.engine] - === System working =========================================
2011-02-23 13:45:24.187::INFO: Extract jar:file:/C:/Geotecnologias/geonetwork/web/geoserver.war!/ to C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\Jetty_localhost_8080_geoserver.war__geoserver__.5rpsuh\webapp
2011-02-23 13:45:53.250::WARN: failed org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,jar:file:/C:/Geotecnologias/geonetwork/web/geoserver.war!/}
java.lang.NoSuchFieldError: KEY_REPLACE_INDEX_COLOR_MODEL
at org.geotools.resources.image.ImageUtilities.<clinit>(ImageUtilities.java:150)
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:70)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:548)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:136)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1234)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:460)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:985)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:194)
at org.mortbay.start.Main.start(Main.java:523)
at org.mortbay.start.Main.main(Main.java:119)
2011-02-23 13:45:53.250::WARN: failed ContextHandlerCollection@anonymised.com
2011-02-23 13:45:53.265::INFO: Opened C:\Geotecnologias\geonetwork\jetty\logs\2011_02_23.request.log
2011-02-23 13:45:53.265::WARN: failed HandlerCollection@anonymised.com
2011-02-23 13:45:53.265::WARN: Error starting handlers
2011-02-23 13:45:53.437::INFO: Started SelectChannelConnector@anonymised.com:8080
Browser:
HTTP ERROR: 404
NOT_FOUNDRequestURI=/geonetwork
Powered by jetty://
----- Original Message -----
To: André Fabiano de Moraes
Cc: geonetwork-users@lists.sourceforge.net
Sent: Wednesday, February 23, 2011 2:14 PM
Subject: Re: [GeoNetwork-users] Problem in the instalation geonetwork 2.6.3 for windowsXP
Hi André
GeoNetwork seem started ok:
2011-02-23 12:30:30,656 INFO [jeeves.engine] - === System working ==============================
, the errors seem related to GeoServer. No other error previous in the log file related to GeoNetwork?
Jose García
GeoCat bv
http://geocat.net
2011/2/23 André Fabiano de Moraes <afdmoraes@anonymised.com>
Thak you Jose García,
...after migration from 2.6.3 database (posgis)....
i have a error in start ....
log
2011-02-23 12:30:30,656 INFO [jeeves.engine] - --- Handler started ---------------------------------------
2011-02-23 12:30:30,656 INFO [jeeves.engine] - Starting schedule manager...
2011-02-23 12:30:30,656 INFO [jeeves.engine] - Memory used is : 15939 Kb
2011-02-23 12:30:30,656 INFO [jeeves.engine] - Total memory is : 506816 Kb
2011-02-23 12:30:30,656 INFO [jeeves.engine] - Startup time is : 8 (secs)
2011-02-23 12:30:30,656 INFO [jeeves.engine] - === System working =========================================
2011-02-23 12:30:31.625::WARN: failed org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/C:/Geotecnologias/geonetwork/web/geoserver/}
2011-02-23 13:45:53.265::WARN: Error starting handlers java.lang.NoSuchFieldError: KEY_REPLACE_INDEX_COLOR_MODEL
2011-02-23 13:45:53.437::INFO: Started SelectChannelConnector@anonymised.com.:8080
HTTP ERROR: 404
Powered by jetty://
Sent: Wednesday, February 23, 2011 11:33 AM
Hi André
Can you check the log file INSTALL_DIR/jetty/logs/geonetwork.log? Should contain some information about why is not starting up GeoNetwork.
Jose García
GeoCat bv
http://geocat.net
I have problem in instalation geonetwork 2.6.3
(geonetwork-install-2.6.3-0.jar) for windowsXP
(http://localhost:8080/geonetwork), after starting the server only shows
the message:
HTTP ERROR: 404
NOT_FOUNDRequestURI=/geonetwork/
Powered by jetty://
.... someone has gone through this problem?
Free Software Download: Index, Search & Analyze Logs and other IT data in
Real-Time with Splunk. Collect, index and harness all the fast moving IT data
generated by your applications, servers and devices whether physical, virtual
or in the cloud. Deliver compliance at lower cost and gain new business
insights. http://p.sf.net/sfu/splunk-dev2dev
GeoNetwork-users mailing list
