[GeoNetwork-users] Parent/child linking across multiple Geonetwork catalogues
I am using Geonetwork 2.10 with ISO19139 records.
Is there any way to create parent/child links between different Geonetwork
catalogues? iso19115 only allows a uuid to be specified for parent linkage
(which must be in the same catalogue), but is there some way to use the
gmx:anchor element to link a child record to a parent record in another
catalogue?
I'm a novice user so I apologise if this is a poorly explained question.
Thanks in advance for your help.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Parent-child-linking-across-multiple-Geonetwork-catalogues-tp5253525.html
2016-03-01 8:20 GMT+01:00 eflukes <emma.flukes@anonymised.com>:
catalogue?
In theory that should be feasible and also was discussed during last year
user meeting in Bern. It's not really supported by the application even if
you may be able to encode the link using an Anchor in the XML view. To have
it in the other views, it'll require some configuration - probably
something similar to what is done for contactInstructions used to store
logo
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/schema-suggestions.xml#L26.
Then it will require extra work on view mode to correctly display the
related record as a link to the remote record (linking to an HTML or XML
document ?).
HTH
Francois
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
GeoNetwork-users mailing list
