[GeoNetwork-users] Please Default Language
Hi there,
I read the post about change default language in GN. I would like to put
catalan as default. I changed the file "index.html"
<html>
        <head>
                <meta http-equiv="Pragma" content="no-cache">
                <meta http-equiv="Cache-Control"
content="no-cache,no-store">
                <link rel="stylesheet" type="text/css"
href="geonetwork.css">
                        </head>
        <body>
JavaScript warning
                <p>To use GeoNetwork you need to enable JavaScript in your
browser</p>
        </body>
</html>
and file config.xml
                 <service>main.home</service>
                <language>ca</language>
                <localized>true</localized>
                <contentType>text/html; charset=UTF-8</contentType>
But it doesn't change. Any idea?
Thanks
Víctor
View this message in context: http://osgeo-org.1560.n6.nabble.com/Please-Default-Language-tp5015883.html
Hi
Seem your index.html misses some javascript code. This should make it work
properly:
<!-- This file will be substituted by the installer with the index.html
template
     Located at gast\data\index.html -->
<html>
<head>
<meta http-equiv="Cache-Control" content="no-cache,no-store">
<link rel="stylesheet" type="text/css" href="geonetwork.css">
*<script language="Javascript1.5" type="text/javascript">*
* var search = window.location.search;*
* window.location="srv/ca/main.home" + search;*
* </script>*
</head>
<body>
<h2>JavaScript warning</h2>
<p>To use GeoNetwork you need to enable JavaScript in your browser</p>
</body>
</html>
Jose García
On Tue, Nov 13, 2012 at 10:14 AM, Vaictor
<victor.fernandez.gayan@anonymised.com>wrote:
Hi there,
<html>
        <head>
                        </head>
        <body>
JavaScript warning
browser</p>
        </body>
</html>
and file config.xml
Thanks
Víctor
Monitor your physical, virtual and cloud infrastructure from a single
web console. Get in-depth insight into apps, servers, databases, vmware,
SAP, cloud infrastructure, etc. Download 30-day Free Trial.
Pricing starts from $795 for 25 servers or applications!
http://p.sf.net/sfu/zoho_dev2dev_nov
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
I have exactly the same and it doesn't work. Is there any other file that I
would edit?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Please-Default-Language-tp5015883p5015887.html
Hi
Check if it's a problem of browser cache. I just tried the change and was
still accessing english version, but after cleaning browser cache the
redirection to catalan page when accessing
http://localhost:8080/geonetworkis fine.
Jose García
On Tue, Nov 13, 2012 at 10:25 AM, Vaictor
would edit?
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Thanks Jose! its was exactly the caché
View this message in context: http://osgeo-org.1560.n6.nabble.com/Please-Default-Language-tp5015883p5015894.html
