[GeoNetwork-users] please help me with z3950 server configuration
I have recently setup geonetwork and have the following problems
question:
How do I add servers for the z3950 remote search?
How do I modify/remove some of the links in the top bar (Links, About Us,
bugs (2.7 snapshot):
The "borders" layer will be added to the map whenever I click Home using
Firefox.
The scrollbar disappears in IE when I create new metadata and upload a file
under transfer options.
The created .kml does not include any WMS information in Google Earth. It
only displays the location.
suggestion:
Align the login form with the main menu >> put the login next to the
language dropbox.
regards, Christoph
View this message in context: http://osgeo-org.1803224.n2.nabble.com/please-help-me-with-z3950-server-configuration-tp7186962p7186962.html
Hi Chris
Responses inline.
Jose GarcĂ­a
On Sat, Jan 14, 2012 at 8:20 AM, chris.may <
Christoph.Mayrhofer@anonymised.com> wrote:
question:
Seem they are configured in the file
geonetwork/WEB-INF/classes/JZKitConfig.xml
Check the file geonetwork/xsl/banner.xsl
Firefox.
The best should be if you open bugs in Trac (
http://trac.osgeo.org/geonetwork/) for these issues, you need an OSGeo
account to login in.
suggestion:
language dropbox.
Same as previous. Also you can change for your installation, modifying in
regards, Christoph
RSA(R) Conference 2012
Mar 27 - Feb 2
Save $400 by Jan. 27
Register now!
http://p.sf.net/sfu/rsa-sfdev2dev2
GeoNetwork-users mailing list
Thanks for the reply. All solutions worked for me, except the z3950 server.
I would like to add USGS:
http://ah-its.com/go2.php?url=library.usgs.gov/././z3950.html
and therefore added the following lines to JZKitConfig.xml
  <Repository className="org.jzkit.search.provider.z3950.Z3950Origin"
code="cfa89068-36ea-11df-9735-ebfc367b61a6" serviceName="USGS">
    <Preferences>
      <Preference name="defaultRecordSyntax">xml</Preference>
      <Preference name="defaultElementSetName">s</Preference>
      <Preference name="host">igsrglib03.er.usgs.gov</Preference>
      <Preference name="port">210</Preference>
      <Preference name="smallSetElementSetName">F</Preference>
      <Preference name="charsetEncoding">UTF-8</Preference>
      <Preference name="useReferenceId">negotiate</Preference>
    </Preferences>
    <RecordArchetypes>
      <Archetype name="F">xml::f</Archetype>
      <Archetype name="H">html::f</Archetype>
    </RecordArchetypes>
    <Collections>
      <Collection code="dataset" name="USGS" profile="geo" />
    </Collections>
However, USGS only appears as a new entry in the profiles, but does not show
up in the servers listbox.
Could you give me instructions how to add USGS z3950?
I would very much appreciate it.
thanks, Chris
View this message in context: http://osgeo-org.1803224.n2.nabble.com/please-help-me-with-z3950-server-configuration-tp7186962p7196231.html
