[GeoNetwork-users] Postgis and Genetwork
Hi All....
I'm trying to use postgis data model as storage for metadata with
geonetwork. I'm using the postgis script file provided with 2.6.0
version.
When a try to startup the application, this row are writed in the log file:
2010-10-08 16:15:18,118 ERROR [jeeves.apphand] - Failed to create
datastore for jdbc:postgis://127.0.0.1/g_metadata. Will use shapefile
instead.
2010-10-08 16:15:18,118 ERROR [jeeves.apphand] - String index out of range: -1
Obviously, the postgis feature aren't used..... any suggestions about
this issue???
My database has only one particularity..... the tables are owned by a
generic user while the postgis trigger are owned by the postgres user.
Can this situation cause some wrong or unstable work?
Thank you for any suggestion or help.
P.S.
The file attached to this mail are the data-db-postgis.sql script
provided with the 2.6.0 version of Geonetwork. In the Setting table,
in the column "version", the version "2.5.0" is used. The same happens
for data-db-posgres.sql. This can cause some migration process runs.
Is this behaviour normal???
Thank you for your help.
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
Ph. D. Student at University of Calabria - DEIS
(attachments)
data-db-postgis.sql (898 Bytes)
