Dear all,
I set up a fresh geonetwork on a unbuntu server 12.04.
Geonetwork 2.10.3, runs in tomcat6, is a war version.
I set up a postgresql-postgis database both for storing metadata
and for managing spatial index. (postgresql vs 9.1.19 and postgis 2).
In config.xml I set postgis driver:
<!-- postgresql --><!-- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - --><resource enabled="true"><name>main-db</name><provider>jeeves.resources.dbms.ApacheDBCPool</provider><config><user>my_user</user><password>my_password</password><!-- we use org.postgis.DriverWrapper in place of
org.postgresql.Driver to support both postgresql and postgis --><driver>org.postgresql.Driver</driver><!--<driver>org.postgis.DriverWrapper</driver>--><!--
jdbc:postgresql:database
jdbc:postgresql://host/database
jdbc:postgresql://host:port/database
or if you are using postgis and want the spatial index loaded
into postgis
jdbc:postgresql_postGIS://host:port/database
--><url>jdbc:postgresql://localhost:5432/geonetwork</url><poolSize>10</poolSize><!-- <reconnectTime>3600</reconnectTime> --><validationQuery>SELECT 1</validationQuery></config></resource>
But using postgis.DriverWrapper seems doesn't work.
Thank you in advance
Eugenio
