[GeoNetwork-users] printPdf error
Hi, everybody
I changed some files of printPdf. But there are some errors in Jetty:
(Location of error unknown) java.io.UTFDataFormatException: Invalid byte 2
of 4-byte UTF-8 sequence.
Also that document.pdf file couldn't open.
Please, help me.
View this message in context: http://www.nabble.com/printPdf-error-tp18585366p18585366.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hello,
On mar, 2008-07-22 at 02:15 -0700, Khishig wrote:
Hi, everybody
Some more questions :
* did the print.pdf service works on your installation with the sample
metadata provided by GeoNetwork ?
* does it work with some of your metadata ?
... I guess Jeroen, also have similar issue on fao node but only with
some metadata. It could be fine to find the metadata causing trouble in
order to fix those characters in the metadata ?
Please, help me
Ciao.
Francois
