[GeoNetwork-users] Privilege setting in MySQL
Dear all,
I attached my question as a pdf file. I did it because I inserted some
screenshots to explain my quesion well.
I would appreciate any help.
Girum Asrat.
(attachments)
GeonetworkQuestions.pdf (25.8 KB)
Dear Girum Asrat,
Changes you've made in the database is correct, but to perform
searches GeoNetwork caches metadata. Of course, this cache is updated
every time you change a metadata properties using web interface of
GeoNetwork itself, but not when you change database behind it. To
force metadata cache to be updated you can stop GeoNetwork (or Tomcat
as a whole), delete cache files located in
'web/geonetwork/WEB-INF/lucene' subfolder of GeoNetworks's directory
and start web service again.
Igor V. Burago
Dear Igor V. Burago,
I followed the steps you suggested and the result was exactly as I wanted.
Thank you for your quick and precise solution.
Best regards,
Girum.
"Igor V. Burago" <iburago@anonymised.com>
06/02/2009 06:50 AM
To
gasrat@anonymised.com
cc
geonetwork-users@lists.sourceforge.net
Subject
Re: [GeoNetwork-users] Privilege setting in MySQL
Dear Girum Asrat,
Igor V. Burago
