[GeoNetwork-users] problem between intermap and geoserver / no map shown
Hi list,
I was wondering if somebody could please assist me with a problem I am
having with geonetwork, intermap and geoserver. Any help would
be very much appreciated.
My problem is that I dont see the map in the geonetwork search
interface.
I have setup geonetwork 2.4.2 on opensuse 11.1 running
apache2,postgresql,tomcat6 and sun java sdk 1.6.
Since I had difficulties to get the geoserver supplied with
geonetwork running, I deployed the latest geoserver.war file
in the tomcat webapps dir.
Geoserver is now operational at http://localhost:8080/geoserver
(I see a login screen and various demos seemed to be running without
problems)
However, as soon as I access http://localhost:8080/intermap or
http://localhost:8080/geonetwork I do see the search interfaces, but
no map is displayed. Instead a "file not found" dummy image having
the source address "intermap/tmp/null" is shown.
Accessing intermap produces the error message shown at the end of this
mail in the tomcat logfile catalina.out .
The mapServers.xml configuration file
/usr/local/geonetwork/web/intermap/WEB-INF/mapServers.xml listst
localhost:8080/geoserver amongst others as available mapservers.
I am not familiar with the geo*-suite, so I was wondering if the
fact that geonetwork requests "tmp/null" images from intermap is
an indicator of an error in geonetwork or if the problem has to
be searched in intermap or geoserver. I was also wondering
if there was a way to chose one of the mapservers configured in the
mapServers.xml file.
any help would be very much appreciated
best regards and many thanks
Timo Proescholdt
============ catalina.out ==============
* skipping null WMSFormat
java.lang.NullPointerException
at
org.wfp.vam.intermap.kernel.map.mapServices.wms.WmsService.<init>(WmsService.java:84)
        at
org.wfp.vam.intermap.services.map.MapUtil.addService(MapUtil.java:190)
        at
org.wfp.vam.intermap.services.map.MapUtil.setDefaultContext(MapUtil.java:243)
        at org.wfp.vam.intermap.services.map.Update.exec(Update.java:67)
        at
jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:238)
       at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
        at java.lang.Thread.run(Thread.java:619)
No valid bbox found
REASPECTING - changing ratio WE += 51.15384
no change to imagename
imagePath: null
Hi Timo,
did you change something at mapservers.xml?
Your Geoserver_data_dir is right?
Just my 2 little suggestions.
best regards
Sarah
Timo Proescholdt wrote:
Hi list,
interface.
problems)
Timo Proescholdt
at
        at
        at
        at
       at
No valid bbox found
imagePath: null
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/problem-between-intermap-and-geoserver-no-map-shown-tp3902074p3904512.html
Hi Timo.
Post here your mapServer.xml....
You can find it in geonetwork/we/intermap/WEB-INF
2009/10/27 Timo Proescholdt <timo@anonymised.com>:
Hi list,
interface.
problems)
Timo Proescholdt
at
at
at
at
at
No valid bbox found
imagePath: null
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
Ph. D. Student at University of Calabria - DEIS
Dear Francesco, Sarah and All,
thank you for your assistance.
please find the mapservers.xml attached to this email.
There might indeed also be an issue with the GEOSERVER_DATA_DIR.
catalina.out complains at one point about
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no
gdaljni in java.library.path
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
28 Oct 12:20:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /usr/share/tomcat6/webapps/geoserver/data
28 Oct 12:20:06 INFO [org.geoserver] - Loaded style 'poi'
28 Oct 12:20:06 INFO [org.geoserver] - Loaded style 'polygon'
however, the directory is owned by tomcat, and seems to contain
the right files.
linux-28ea:/usr/share/tomcat6/webapps/geoserver # ls data/
coverages demo layergroups logs plugIns styles
validation wfs.xml workspaces
data global.xml logging.xml palettes security user_projections
wcs.xml wms.xml www
is there an issue with the GEOSERVER_DATA_DIR? What is it supposed to
contain and what is it for?
any clues what the NullPointerException and the "* skipping null WMSFormat"
messages in catalina.out are about?
thank you and best regards
Timo
Hi Timo.
Hi list,
interface.
problems)
Timo Proescholdt
at
at
at
at
at
No valid bbox found
imagePath: null
stay
(IIA)
(attachments)
mapServers.xml (6.23 KB)
Timo, in default section you are this services:
<mapContexts>
    <default name="Layers for default map -- DUMMY NAME:not used">
      <server url="http://localhost:8080/geoserver/wms&quot; type="2" >
        <layer name="gn:world"></layer>
      </server>
        <layer name="gn:gboundaries"></layer>
      </server>
Are you installed geoserver embedded in your local host???
If so, you can reach the server
http://localhost:8080/geoserver/wms… try it. If not, the problem
is related to geoserver installation.
I think that the problem is with embedded geoserver....
Try to reinstall Geonetowkr but without geoserver... next install a
geoserver.war only if you need a map server.
The default tag in mapserver.xml will appear to address in a remote
web map server, metacarta vmap probably.
2009/10/28 Timo Proescholdt <timo@anonymised.com>:
the right files.
wcs.xml wms.xml www
Timo
Hi Timo.
Hi list,
interface.
problems)
Timo Proescholdt
at
at
at
at
at
No valid bbox found
imagePath: null
stay
(IIA)
Dear Francesco,
thanks again for your help.
<mapContexts>
      </server>
      </server>
yes, I installed geoserver on the same host, and thought to get the
default map from there.
http://localhost:8080/geoserver/wms gives my an XML file. I also tested
something like http://localhost:8080/geoserver/wms???CAPABILITIES???
at some point (cannot find the exact URL any more) and it returned an
XML file with the server capabilities, which seemd to be ok.
Are there any other parameters that I could try?
you might be right but I'm not sure. I'm getting the geoserver login
screen and so far it seemed to be ok. How can I test that the geoserver
really works without problems? What are the parameters needed to make
it output an actual map?
thanks!
Timo
In the early mail you said that you had deployed a geoserver.war.....
1) Undeploy this geoserver.war
2) Restart Tomcat (if you use it.... or restart Jetty or GN stand alone).
3)Restart Geonetwork (o restart tomcat).
go to : http://localhost:8080/geoserver
Go to Welcome page and search demo....
In demo page there is same feature (WMS) that you can try.......
gn:gboundaries and gn:world.
Try this feature....... if is ok geoserver works fine.
4)Try http://localhost:8080/intermap
The map is showed???
5) Try GeoNetowrk.... if step 3 and step 4 are ok, Geonetowrk should be ok......
Good luck!!!!
Dear Francesco,
<mapContexts>
</server>
</server>
thanks!
Timo
Hi guys,
1000 thanks for your help.
Uninstalling (rm -rf /usr/local/geonetwork) geonetwork and installing it
again without geoserver solved the problem. (I redeployed geoserver.war
in tomcat, too).
The map is now being displayed.
thanks again and have a nice evening!
Timo
Good work!!!!
Get attention with mapserver.xml...... may be that the map in there
don't work well some times....
Change it with World map contains in your local geoserver!!!!!! It
will work better!!!
Ciao.
Hi guys,
in tomcat, too).
Timo
