[GeoNetwork-users] problem building the installer
Hi list,
I tried to rebuild the installer with ant, but the build failed :
First the prompt windows shows this error : cannot find
C:\geonetwork\docs\build.xml, which is not absurd since there is no such
file in the docs directory (altough I installed GeoNetwork with all the
possible options) .
I tried to put in comment the line calling for this file in the
installer\build.xml file like this :
(l.120) <!-- <ant dir="../docs" target="all" /> -->
but I obtain a lot of errors including including izpack problems : it says
the installer-config-xml file is invalid...
What can I do? Is there a problem with the installer\build.xml file? Or
maybe I should find the complete docs directory, with the build files? But
where?
Please help me!!
Regards
Eliane
PS : this is what I see in the wimdows prompt
http://www.nabble.com/file/p18709265/installer-error.jpg
View this message in context: http://www.nabble.com/problem-building-the-installer-tp18709265p18709265.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Eliane,
there has been a problem in the build script, but it is fixed now.. I'm not
sure if the error was still in the 2.2.0 release. Try taking the sources
from the SVN trunk, it should build fine.
Kind regards
Heikki Doeleman
On Tue, Jul 29, 2008 at 3:26 AM, eliane <eliane.roos@anonymised.com> wrote:
Hi list,
possible options) .
where?
Please help me!!
Regards
Eliane
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-users mailing list
Hi Heikki
Thanks a lot for your fast answer.
You were right I didn't had the good files, but I still have some problems.
I managed to build an istaller
(I took the docs, installer and schematron repository, and the files
MapServers.xml_with_geoserver and Jetty.xml_with_geoserver from the trunk
in SVN. I also had to give the complete path to izpack (l.127 in
installer/build.xml) as it didn't understand the relative one)
But when I tried the installer :
First I had an error at the end of the installation, probably because I
changed the dbms (it says the login and the password are not recognised)
Then Jetty doesn't start...
Do you think the problem with Jetty is linked to this database
configuration problem?
And if not, an idea about what else could it be?
Kind regards
cheers
Eliane
Hi Eliane,
not
Kind regards
Heikki Doeleman
Hi list,
possible options) .
says
But
where?
Please help me!!
Regards
Eliane
challenge
prizes
world
Hi Eliane,
yes, the installer build generates a username and password for the DBMS
(--apparently someone thought this a dandy idea--) which is why you'll
always get errors when using the installer using anything but an embedded
McKoi DB. These errors shouldn't matter though, just click OK and Continue
and the install should go fine.
So after installing, you'll need to edit
<installation-dir>/web/geonetwork/WEB-INF/config.xml and enter the correct
authentication for your MySQL (or whatever DBMS you're using). Assuming you
already created the GeoNetwork database, for example using the GAST tool.
After this Jetty should start fine. If it doesn't for you, could you send
the errors you get in the log file ? The log files in
<installation-dir>/jetty/log may contain more information than what is put
out to the console.
Kind regards,
Heikki Doeleman
On Wed, Jul 30, 2008 at 6:48 AM, Eliane Roos <Eliane.Roos@anonymised.com> wrote:
Hi Heikki
Kind regards
cheers
Eliane
Hi Eliane,
> not
> Kind regards
> Heikki Doeleman
>> Hi list,
>> possible options) .
>> says
>> But
>> where?
>> Please help me!!
>> Regards
>> Eliane
>> challenge
>> prizes
>> world
>> _______________________________________________
Hi Heikki
The problem is that Jetty doesn't start at all, (the prompt window doesn't
open), and there is no log file created for the good day...
I tried to re build the installer using Mckoi to avoid the PostgreSQL
problems but it is the same...
So I don't know what to do...
I will compare the installer files I took in the SVN trunk, with the ones
which cames with the installer, but I do not have much hope with that...
Do you have a clue for that?
Sorry to take you time and thanks a lot for your answer!!
Eliane
Hi Eliane,
you
out to the console.
Kind regards,
Heikki Doeleman
Hi Heikki
problems.
trunk
Kind regards
cheers
Eliane
Hi Eliane,
I'm
> not
sources
> Kind regards
> Heikki Doeleman
>> Hi list,
such
the
>> possible options) .
>> says
Or
files?
>> But
>> where?
>> Please help me!!
>> Regards
>> Eliane
>> challenge
great
>> prizes
>> world
Hi Heikki
I found the problem!
(I tried to build a installer without jre, whereas I have installed
initially with jre, and because of that the paths were not good, and Jetty
didn't work)
Thanks a lot for your attention and your answers!!
Eliane
Hi Heikki
Eliane
Hi Eliane,
embedded
Continue
correct
you
tool.
send
put
out to the console.
Kind regards,
Heikki Doeleman
wrote:
Hi Heikki
problems.
trunk
recognised)
Kind regards
cheers
Eliane
Hi Eliane,
I'm
> not
sources
> Kind regards
> Heikki Doeleman
>> Hi list,
such
the
>> possible options) .
it
>> says
Or
files?
>> But
>> where?
>> Please help me!!
>> Regards
>> Eliane
>> challenge
great
>> prizes
the
>> world
