[GeoNetwork-users] problem configuring MySQL
Hello!
My name is Adam Soroka. I'm bringing up a Geonetwork instance at the University of Virginia Library. We're using Tomcat 5.5.25 and MySQL 5.0.27, or rather, we're trying to. {grin}
I'm getting a error message when I try to use GAST to configure the database. I'm fairly sure I've got the connections lined up properly and passwords in place and so forth. Here's the error:
Error
Cyclic reference found:
[Metadata, MetadataCateg, OperationAllowed]
and then when I okay that dialog box to move on, I'm given:
MySQLSyntaxErrorException
Specified key was too long: max key length is 1000 bytes
The readout at the console doesn't include the stacktrace for the first-- just the second:
346138 [Thread-7] INFO gast - Removing database objects
356087 [Thread-7] INFO gast - Creating database schema
com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: Specified key was too long; max key length is 1000 bytes
         at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:936)
         at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2985)
         at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1631)
         at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1723)
         at com.mysql.jdbc.Connection.execSQL(Connection.java:3256)
         at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1313)
         at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1585)
         at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1500)
         at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1485)
         at jeeves.resources.dbms.Dbms.execute(Dbms.java:256)
         at jeeves.resources.dbms.Dbms.execute(Dbms.java:232)
         at org.fao.gast.lib.DatabaseLib.createSchema(DatabaseLib.java:391)
         at org.fao.gast.lib.DatabaseLib.setup(DatabaseLib.java:103)
         at org.fao.gast.gui.panels.database.setup.Worker.run(Worker.java:59)
         at java.lang.Thread.run(Thread.java:595)
I don't see anything at all show up in the Tomcat or the MySQL logs.
Any thoughts?
Thanks-- it looks like a great system and we're really looking forward to bringing it up.
A. Soroka ; DSS R&D / University of Virginia Library
With regards to the cyclic reference in MySQL, it does not seem to prevent geonetwork from working. I ignored it, and it seems to work, although it should be looked into.
The other message is likely caused by the encoding scheme of your databsae. Unless you need to use something other than LATIN1, don't. I got the same message when I created a geonetwork datbase with the UTF8 encoding scheme. Using LATIN1 works fine. If you need to use UTF8, you may need to make changes to your MySQL instance, but maybe as a first step you can try to create the database with the LATIN1 scheme.
Best regards,
Jason Pickering
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net on behalf of ajs6f
Sent: Wed 10/31/2007 5:36 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] problem configuring MySQL
Hello!
Error
936)
(Worker.java:59)
Any thoughts?
GeoNetwork-users mailing list
Error
This happens occasionally to me with the default, non-MySQL setup.
Running the database initialization immediately for a second time seems
to resolve the problem. My guess is that it's just related to the order
in which the tables are being deleted before recreating them.
Archie
-- Archie Warnock warnock@anonymised.com
-- A/WWW Enterprises www.awcubed.com
-- As a matter of fact, I _do_ speak for my employer.
That happened to me using McKoi as well, but I also was able to run it again with success. However, I'm required to bring this instance up with MySQL.
Error
Archie
Actually, one reason we're so excited about Geonetwork is that we support a large community of scholars here that study the Himalayan region. They use languages with all kinds of (non-Roman) scripts, and they work from large GIS collections. So we'd very much like to bring this up using a MySQL database able to handle UTF-8.
Has anyone out there successfully done so? Do we know what changes might be needed to the MySQL instance?
hopefully,
Best regards,
Jason Pickering
Hello!
Error
936)
(Worker.java:59)
Any thoughts?
I've taken Mr. Pickering's advice and tried setup with a MySQL database using LATIN1. It did the trick with the 'setup' problem.
Thanks!
But now I'm getting a completely different blockage.
I'm getting "The requested operation could not be performed." all over the website (caused by the sort of exception I've quoted out twice at the bottom of the message; once thrown for trying to login to the web admin interface and once for loading part of the main page).
Also, the 'sample data' functionality in GAST now throws a Exception: <no message> and the stack trace is shown below (third of three).
Any thoughts? I'm a bit stuck because it's a generic NullPointerException and I don't know much about the actual code.
Exception thrown by trying to login to the web admin interface:
2007-11-01 13:48:26,526 INFO [jeeves.request] - ==========================================================
2007-11-01 13:48:26,527 INFO [jeeves.request] - HTML Request (from 128.143.193.233) : /geonetwork/srv/en/user.login
2007-11-01 13:48:26,527 DEBUG [jeeves.request] - Method : POST
2007-11-01 13:48:26,527 DEBUG [jeeves.request] - Content type : application/x-www-form-urlencoded
2007-11-01 13:48:26,527 DEBUG [jeeves.request] - Accept : text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
2007-11-01 13:48:26,527 INFO [jeeves.service] - Dispatching : user.login
2007-11-01 13:48:26,528 DEBUG [jeeves.service] - -> parameters are :
<request>
   <password>admin</password>
   <username>admin</username>
</request>
2007-11-01 13:48:26,528 ERROR [jeeves.service] - Exception when executing service
2007-11-01 13:48:26,528 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2007-11-01 13:48:26,529 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
   <message />
   <class>NullPointerException</class>
   <stack>
     <at class="org.fao.geonet.services.login.Login" file="Login.java" line="67" method="exec" />
     <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="238" method="execService" />
     <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="141" method="execServices" />
     <at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="372" method="dispatch" />
     <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="600" method="dispatch" />
     <at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="163" method="execute" />
     <at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="98" method="doPost" />
     <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="710" method="service" />
     <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="803" method="service" />
     <at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="269" method="internalDoFilter" />
   </stack>
   <request>
     <language>en</language>
     <service>user.login</service>
   </request>
</error>
2007-11-01 13:48:26,529 INFO [jeeves.service] - -> dispatching to error for : user.login
2007-11-01 13:48:26,638 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2007-11-01 13:48:26,639 ERROR [jeeves.service] - (C) Stack trace is :
         at org.fao.geonet.guiservices.util.Env.exec(Env.java:53)
         at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
         at jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
         at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:103)
         at jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:668)
         at jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:460)
         at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:405)
         at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:600)
         at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:163)
         at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:98)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
         at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
         at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
         at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
         at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
         at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
         at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
         at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
         at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
         at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
         at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
         at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
         at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
         at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
2007-11-01 13:48:26,642 INFO [jeeves.service] - -> transforming with stylesheet : /usr/local/projects/geonetwork/web/geonetwork/xsl/error.xsl
2007-11-01 13:48:26,773 INFO [jeeves.service] - -> end error transformation for : user.login
2007-11-01 13:48:26,773 INFO [jeeves.service] - -> error ended for : user.login
Exception thrown by the main page trying to get a service:
2007-11-01 13:49:39,123 INFO [jeeves.webapp.main.home] - Returning search data
2007-11-01 13:49:39,124 ERROR [jeeves.service] - Exception executing gui service : java.lang.NullPointerException
2007-11-01 13:49:39,124 ERROR [jeeves.service] - (C) Stack trace is :
         at org.fao.geonet.guiservices.keywords.Get.exec(Get.java:55)
         at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:104)
         at jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:584)
         at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:378)
         at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:88)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
Exception thrown by trying to import sample data in GAST:
323951 [Thread-4] WARN cookie.CookieSpec - Invalid cookie state: domain not specified
323956 [Thread-4] WARN httpclient.HttpMethodBase - Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
*** Error is:
<error id="error">
   <message />
   <stack>
     <at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="88" method="doGet" />
     <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="690" method="service" />
   </stack>
   <request>
     <service>xml.user.login</service>
   </request>
</error>
java.lang.Exception:
         at org.fao.gast.lib.ServiceLib.checkError(ServiceLib.java:82)
         at org.fao.gast.lib.ServiceLib.login(ServiceLib.java:53)
         at org.fao.gast.gui.panels.database.sample.Worker.login(Worker.java:125)
         at org.fao.gast.gui.panels.database.sample.Worker.executeJob(Worker.java:96)
         at org.fao.gast.gui.panels.database.sample.Worker.run(Worker.java:73)
Best regards,
Jason Pickering
Hello!
Error
936)
(Worker.java:59)
Any thoughts?
Glad to see that LATIN1 worked. However, if you need to use UTF8
encoding, then I suspect that the database needs to be modified.
I believe this is causing the problem.
CREATE TABLE `Metadata` (
  `id` int(11) NOT NULL default '0',
  `uuid` varchar(250) collate latin1_bin NOT NULL,
  `schemaId` varchar(32) collate latin1_bin NOT NULL,
  `isTemplate` char(1) collate latin1_bin NOT NULL default 'n',
  `isHarvested` char(1) collate latin1_bin NOT NULL default 'n',
  `createDate` varchar(24) collate latin1_bin NOT NULL,
  `changeDate` varchar(24) collate latin1_bin NOT NULL,
  `data` text collate latin1_bin NOT NULL,
  `source` varchar(250) collate latin1_bin NOT NULL,
  `title` varchar(255) collate latin1_bin default NULL,
  `root` varchar(255) collate latin1_bin default NULL,
  `harvestUuid` varchar(250) collate latin1_bin default NULL,
  `owner` int(11) NOT NULL,
  `groupOwner` int(11) default NULL,
  `harvestUri` varchar(255) collate latin1_bin default NULL,
  `rating` int(11) NOT NULL default '0',
  `popularity` int(11) NOT NULL default '0',
  PRIMARY KEY (`id`),
  UNIQUE KEY `uuid` (`uuid`,`source`,`harvestUuid`),
  KEY `owner` (`owner`),
  KEY `groupOwner` (`groupOwner`),
  KEY `MetadataNDX1` (`uuid`),
  KEY `MetadataNDX2` (`source`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 COLLATE=latin1_bin;
This is my metadata table as dumped from MySQL. The unique key length is
too long . However, the composite fields, namely uuid and harvestUuid
are listed at varchar (255). This field length is too long, and I assume
that this data could be stored in a much shorter field length. I have
not delved into the code either at this point, but see no reason why a
UUID needs to be stored in a varchar(255) column. This would have the
effect of shortening the key length certainly improving performance. If
you need multibyte encodings such as UTF8, shorten the field length to
32 and see what happens.
Maybe the developers can comment here?
With regards to this error, did you try and restart Tomcat?
Best regards,
Jason
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of
ajs6f
Sent: 01 November 2007 19:29
Subject: Re: [GeoNetwork-users] problem configuring MySQL (improving but
newproblem with sample data)
Thanks!
user.login
<request>
</request>
executing service
<error id="error">
   <message />
   <stack>
   </stack>
   <request>
   </request>
</error>
75)
         at
         at
error.xsl
for : user.login
search data
75)
         at
         at
*** Error is:
<error id="error">
   <message />
   <stack>
   </stack>
   <request>
   </request>
</error>
(Worker.java:125)
(Worker.java:96)
(Worker.java:73)
the LATIN1 scheme.
Best regards,
Jason Pickering
ajs6f
Hello!
Error
936)
(Worker.java:59)
Any thoughts?
browser.
projects/geonetwork
Regarding my "NullPointerException" problems-- restarting Tomcat did the trick. I had been reloading the app with the Tomcat manager, but perhaps there's some kind of interaction with the servlet container context that requires a restart after certain things?
Regarding the Unicode question: Mr. Pickering's suggestion was excellent, but I had to make one alteration. It turns out that those field must be 36 characters to accept the sample data from GAST. This is because UUIDs are being stored as sections of hex digits separated by hyphens.
Thanks very much to Mr. Pickering for his help. I'm going to go look at the bug reports, and if this Unicode setup issue isn't there, I think I'll put it in. It's clearly not a big deal, but it did confuse me.
A. Soroka
  PRIMARY KEY (`id`),
Best regards,
Jason
ajs6f
Thanks!
user.login
<request>
</request>
executing service
<error id="error">
   <message />
   <stack>
   </stack>
   <request>
   </request>
</error>
75)
         at
         at
error.xsl
for : user.login
search data
75)
         at
         at
*** Error is:
<error id="error">
   <message />
   <stack>
   </stack>
   <request>
   </request>
</error>
(Worker.java:125)
(Worker.java:96)
(Worker.java:73)
the LATIN1 scheme.
Best regards,
Jason Pickering
ajs6f
Hello!
Error
936)
(Worker.java:59)
Any thoughts?
browser.
projects/geonetwork
I have the same problem as yours (The requested operation could not be
performed because of NullPointerException when log in). I have restarted
Tomcat already but I still got this error when log in. Can you tell me
another way to solve this.
Binh Pham
by hyphens.
me.
A. Soroka
  PRIMARY KEY (`id`),
length is
assume
performance. If
Best regards,
Jason
ajs6f
(improving but
Thanks!
page).
user.login
<request>
</request>
executing service
<error id="error">
   <message />
   <stack>
   </stack>
   <request>
   </request>
</error>
75)
710)
803)
         at
665)
         at
error.xsl
for : user.login
search data
75)
690)
803)
         at
665)
         at
*** Error is:
<error id="error">
   <message />
   <stack>
   </stack>
   <request>
   </request>
</error>
(Worker.java:125)
(Worker.java:96)
(Worker.java:73)
the LATIN1 scheme.
Best regards,
Jason Pickering
ajs6f
Hello!
Error
936)
2985)
(Worker.java:59)
Any thoughts?
browser.
projects/geonetwork
browser.
View this message in context: http://www.nabble.com/problem-configuring-MySQL-tf4726270s18419.html#a13908786
Sent from the geonetwork-users mailing list archive at Nabble.com.
