Hello geonetwork-users!
This is my first post on this list, so i introduce myself as geologist and
gdi-administrator in a civil engineering company in germany. I have about
20 years experience with GIS and about 10-15 years with OGC-Webservices and
postgres.
I like to evaluate geonetwork because we need the ability to host a
metadata catalogue and some maps as documentation for our customers.
I have a preexisting tomcat 7 with geoserver and postgresql/postgis
9.3/2.1.3 in use. All is running on OpenSuse 13.1 Machines.
I have installed the geonetwork.war file, which worked. I configured the
database connection in 'WEB-INF/config-node/srv.xml', then i configured
the connection in 'WEB-INF/config-db/jdbc.properties'.
But when i try to start the application in tomcat the following error is
found in /var/log/tomcat/geonetwork.log (see pastebin-link below).
The pg_hba-entry seems also correct because i can login with psql with the
given parameters from the tomcat machine.
So i am a little bit clueless and hope you can help me with some hints.
Thank you in advance for your help.
Uwe Seher
http://pastebin.com/0K1U2Yqj
Hi Uwe
Seem an issue of your Postgres configuration. See this error:
FATAL: no pg_hba.conf entry for host "192.168.1.2", user "gdi_admin ",
database "geonetwork", SSL off
Check to add the proper configuration, you need to authorise the host/user
to access. Is the database in the same server as GeoNetwork? If so try to
configure the connection with localhost.
Jose García
postgres.
Uwe Seher
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>M: +31 (0)655 818332 <+31655818332>
<https://www.facebook.com/geocatbv> <https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
No, the database is on another server. But i can log in with psql from the
tomcat-server with the given credentials. Other applications like geoserver
and jasperreports which run on the same server like geonetwork do not have
problems. Altering the entry in pg_hba has the predicted effect. I had
restarted the database after changes, also the tomcat.
So this is a little strange to me.
Uwe
2015-09-15 16:40 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Uwe
Jose García
and
postgres.
Uwe Seher
Hi again!
As i said, login with psql or pgadmin using the geonetwork-user is working
in the local network.
This is the relvant entry in pg_hba.conf:
host geonetwork +gdi,+web 192.168.1.0/24 md5
CU
Uwe
2015-09-15 19:59 GMT+02:00 gannebamm <gannebamm@anonymised.com>:
http://dba.stackexchange.com/questions/83984/connect-to-postgresql-server-fatal-no-pg-hba-conf-entry-for-host
I had this issue with PostgreSQL and needed to add my ip to the conf file
Sent from mobile
---- Uwe Seher schrieb ----
Uwe
> Hi Uwe
host/user
> Regards,
> Jose García
and
about
>> and
>> postgres.
the
configured
the
>> Uwe Seher
>> _______________________________________________
+31
> (0)318 416664 <+31318416664>M: +31 (0)655 818332 <+31%20(0)655%20818332>
<+31655818332>
> <https://www.facebook.com/geocatbv>&nbsp; <
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please> consider the
Hi Uwe
See comments inline.
Jose García
On Wed, Sep 16, 2015 at 8:19 AM, Uwe Seher <uwe.seher@anonymised.com> wrote:
Hi again!
Sure, but most probably these applications use local connections instead of
host (tcp/ip). If you check in your file, you should have another entry
like this:
local geonetwork ...
or
local all ...
That explains why these applications worked, but no GeoNetwork that
requires tcp/ip access.
CU
Uwe
> Sent from mobile
the
geoserver
have
> Uwe
> > Hi Uwe
> host/user
to
> > Regards,
> > Jose García
> and
> about
OGC-Webservices
> >> and
> >> postgres.
> the
> configured
is
> the
hints.
> >> Uwe Seher
> +31
> <+31655818332>
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools
in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
local is for socket connections which works only on the same machine.
pg_hba.conf is processed on line after the other until a match occurs. If
no match occurs the above error is raised. If i comment the local-enties
out it remains all the same. I pushed the geonetwork-entry to the first
line and allowed trusted access for all but the error still remains with
geonetwork while other connection are processed in the right way. I can see
the access-attempt in the postgres-log, and i can connect to the
geonetwork-database with geoserver, which runs on the same machine with the
same tomcat.
At this point in time i only edited in config-db/jdbc.properties and
config-node/srv.xml. This seems to be correct, because i can watch the
connection attempt on both sides. Also the changed entries are visible. But
maybe i have something missed or forgotten?
Now i will try to get it up on my laptop, where i can test the local-issue.
This is a really strange thing.
CU Uwe
2015-09-16 8:26 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Uwe
Jose García
Hi again!
of host (tcp/ip). If you check in your file, you should have another entry
like this:
or
local all ...
CU
Uwe
file
> Sent from mobile
the
geoserver
have
> Uwe
> > Hi Uwe
> host/user
try to
> > Regards,
> > Jose García
geologist
> and
> about
OGC-Webservices
> >> and
> >> postgres.
> the
> configured
error is
with
> the
hints.
> >> Uwe Seher
NetherlandsT:
> +31
> <+31655818332>
in one place.
Hi Uwe,
is there a typo in your configured username? It seems there's an additional
blank in "gdi_admin ". At least that's what shows up in the stack trace:
(FATAL: no pg_hba.conf entry for host "192.168.1.2", user "gdi_admin ",
database "geonetwork", SSL off)
Cheers, Michael
2015-09-16 10:37 GMT+02:00 Uwe Seher <uwe.seher@anonymised.com>:
same tomcat.
CU Uwe
> Hi Uwe
> Regards,
> Jose García
>> Hi again!
working
entry
> like this:
> or
> local all ...
>> CU
>> Uwe
>> file
>> > Sent from mobile
>> the
>> geoserver
>> have
>> > Uwe
>> > > Hi Uwe
>> > host/user
>> try to
>> > > Regards,
>> > > Jose García
>> geologist
>> > and
>> > about
>> OGC-Webservices
>> > >> and
>> > >> postgres.
customers.
configured
>> > the
>> > configured
>> error is
>> with
>> > the
>> hints.
>> > >> Uwe Seher
>> NetherlandsT:
>> > +31
>> > <+31655818332>
the
>> in one place.
+31
in one place.
Michael Schulz
Ok, i hunted it down. There has been a space at the end of the username, a
small nothing with a great effect.
I thank you all for your help and continue banging my head on the table
Bye
Uwe
