[GeoNetwork-users] problem in adding new harvester
Dear all,
I have a big problem in adding a new harvester.Unfortunately I couldn't fine any up-to-date guideline for how to add a new harvester to GN. The only one which I found is the developer manual for the release 2.10.4-0. and apparently this document is not valid.I want to add a separate OGC SOS harvester (I know that GN has already one for OGC web services) which harvest describesensors and not only getcapabilities.I did test alot of things and these are the final steps I made:
1. I added the Java code in a package inside org.fao.geonet.kernel.harvest.harvester.ogcsos which contains OgcSOSHarvester.java and OgcSoSParams.java (and also Harvester.java).
2. I added one line to haresters/src/main/resources/config-spring-geonetwork with identical bean ID = ogcsos.3. I added the transformation stylesheet in web/src/main/webapp/xsl/xml/harvesting/ogcsos.xml. [Its name must match the string used for the harvesting type.]4. I added the ogcsos.js and ogcsos.html in the folder web-ui/src/main/resources/catalog/templates/admin/harvest/type.
** I am working with the version 3.4.2.
What I receive is only in the harvester webpage, from the dropdown I have the name of my OGC SOS but by click on it it does not call any template. What else do I need to check?In the old manual it refers to harvesting.xml file. Where is this file located in my GN version?What is the harvester setting table? where can i find this?
Many thanks in advance for your adviceMani
Well do you have javascript errors when you try to load your new SOS
Harvester ?
Would you have a branch pointing on your changes ?
On Tue, Sep 18, 2018 at 10:47 AM mane moshref via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
*Front-end Technical Leader*
+33 4 58 48 20 36
Thanks for the reply.in my browser inspector when I click on my SOS harvester I receive this error:
Error: window[("gnHarvester" + b)] is undefineda.addHarvester@anonymised.com://localhost:8080/geonetwork/static/gn_admin.js:1171:1fn@anonymised.com://localhost:8080/geonetwork/static/lib.js line 742 > Function:4:379b@anonymised.com://localhost:8080/geonetwork/static/lib.js:639:317e@anonymised.com://localhost:8080/geonetwork/static/lib.js:783:394$eval@anonymised.com://localhost:8080/geonetwork/static/lib.js:658:269$apply@anonymised.com://localhost:8080/geonetwork/static/lib.js:658:501compile/</<@http://localhost:8080/geonetwork/static/lib.js:783:444dispatch@anonymised.com://localhost:8080/geonetwork/static/lib.js:9:9954add/y.handle@anonymised.com://localhost:8080/geonetwork/static/lib.js:9:6772
one more question when I run the web service where the geonetwork log file is stored?
Honestly, I haven't yet fully create my harvester so I just mannually create sth which mainly copy and past the ogcwxs folder which some changes in the code to see whether it work or not and then wanted to directly work on the code.
Thanks in advanceMandana On Tuesday, September 18, 2018, 10:52:42 AM GMT+2, Florent Gravin <florent.gravin@anonymised.com> wrote:
Well do you have javascript errors when you try to load your new SOS Harvester ?Would you have a branch pointing on your changes ?
On Tue, Sep 18, 2018 at 10:47 AM mane moshref via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
camptocampINNOVATIVE SOLUTIONSBY OPEN SOURCE EXPERTS
Florent GravinFront-end Technical Leader+33 4 58 48 20 36
Oh, it works. Thanks for the hint. surprisingly randomly when I run it, it clears the whole content of my ogcsos.js file. I do not know why it behaves like that. now I should start to test my own code for running the describesesnor.
ThanksMani On Tuesday, September 18, 2018, 10:52:42 AM GMT+2, Florent Gravin <florent.gravin@anonymised.com> wrote:
Dear all,
