[GeoNetwork-users] Problem in harvesting
Dear all,
I am struggling with the harvester of Geonetwork. I am trying to harvest a SOS:http://insitu.webservice-energy.org/52n-sos-webapp/sos?SERVICE=SOS&VERSION=1.0.0&REQUEST=GetCapabilities
which should work however I get this error:
org.fao.geonet.utils.Xml Xml.java (382) #transform
org.fao.geonet.kernel.harvest.harvester.ogcwxs.Harvester Harvester.java (330) #addMetadata
org.fao.geonet.kernel.harvest.harvester.ogcwxs.Harvester Harvester.java (242) #harvest
org.fao.geonet.kernel.harvest.harvester.ogcwxs.OgcWxSHarvester OgcWxSHarvester.java (150) #doHarvest
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor AbstractHarvester.java (649) #process
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester AbstractHarvester.java (721) #harvest
org.fao.geonet.kernel.harvest.harvester.HarvesterJob HarvesterJob.java (57) #execute
org.quartz.core.JobRunShell JobRunShell.java (213) #run
org.quartz.simpl.SimpleThreadPool$WorkerThread SimpleThreadPool.java (557) #run
Can someone tell me what is the problem? and how can I solve it?
best regardsMani
Hi
The problem seem the version of SOS supported is only 1.0, not 2.0 as in
the service you are using.
I opened a issue to track this:
https://github.com/geonetwork/core-geonetwork/issues/2686
I quick fix (but will drop the support for SOS 1.0), is that you change
https://github.com/geonetwork/core-geonetwork/blob/3.4.x/schemas/iso19139/src/main/plugin/iso19139/convert/OGCWxSGetCapabilitiesto19119/OGCSOSGetCapabilities-to-19119.xsl#L31
to
xmlns:sos="http://www.opengis.net/sos/2.0"
But probably also some changes will be required in the xslt as probably
Capabilities for SOS 2.0 has differences with SOS 1.0.
Jose García
On Mon, Apr 16, 2018 at 10:15 AM, mane moshref via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
(330) #addMetadata
(242) #harvest
(57) #execute
(557) #run
best regardsMani
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Many Thanks Jose for your prompt answer.
In harvester I have to choose the service type which is SOS1.0.0 So anyway I believe it only works for SOS1.0.0. as you said it needs some work on xslt.But as the getCapabalities also works for version 1 here I thought there shouldn't be any problem for the version.
    On Monday, April 16, 2018, 10:43:13 AM GMT+2, Jose Garcia <jose.garcia@...444...> wrote:
Hi
The problem seem the version of SOS supported is only 1.0, not 2.0 as in the service you are using.
I opened a issue to track this: https://github.com/geonetwork/core-geonetwork/issues/2686
I quick fix (but will drop the support for SOS 1.0), is that you change https://github.com/geonetwork/core-geonetwork/blob/3.4.x/schemas/iso19139/src/main/plugin/iso19139/convert/OGCWxSGetCapabilitiesto19119/OGCSOSGetCapabilities-to-19119.xsl#L31
to
xmlns:sos="http://www.opengis.net/sos/2.0&quot;
But probably also some changes will be required in the xslt as probably Capabilities for SOS 2.0 has differences with SOS 1.0.
Regards,Jose García
On Mon, Apr 16, 2018 at 10:15 AM, mane moshref via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
I am struggling with the harvester of Geonetwork. I am trying to harvest a SOS:http://insitu.webservice- energy.org/52n-sos-webapp/sos? SERVICE=SOS&VERSION=1.0.0& REQUEST=GetCapabilities
org.fao.geonet.kernel.harvest. harvester.ogcwxs.Harvester Harvester.java (330) #addMetadata
org.fao.geonet.kernel.harvest. harvester.ogcwxs.Harvester Harvester.java (242) #harvest
org.fao.geonet.kernel.harvest. harvester.ogcwxs. OgcWxSHarvester OgcWxSHarvester.java (150) #doHarvest
org.fao.geonet.kernel.harvest. harvester.AbstractHarvester$ HarvestWithIndexProcessor AbstractHarvester.java (649) #process
org.fao.geonet.kernel.harvest. harvester.AbstractHarvester AbstractHarvester.java (721) #harvest
org.fao.geonet.kernel.harvest. harvester.HarvesterJob HarvesterJob.java (57) #execute
org.quartz.simpl. SimpleThreadPool$WorkerThread SimpleThreadPool.java (557) #run
best regardsMani
______________________________ _________________
GeoNetwork-users@anonymised.com sourceforge.net
https://lists.sourceforge.net/ lists/listinfo/geonetwork- users
GeoNetwork OpenSource is maintained at http://sourceforge.net/ projects/geonetwork
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Dear all,
I have the same problem too.
I'm trying to harvest a SOS but I'm having the same problem:
(330) #addMetadata
(242) #harvest
org.fao.geonet.kernel.harvest.harvester.HarvesterJob HarvesterJob.java (51)
#execute
#run
I understood that within the OGC WxS there the harvester for SOS.
In my case the service provider support both SOS 1.0.0 and 2.0.0.
Since GN support the SOS 1.0.0 and my provider provide the service at
version 1.0.0 and 2.0.0 I don't understand the problem.
I set:
the service URL as http://my_provider_name/observations/sos/kvp
sos1.0.0
schema output iso19139
XLS transformation: OGCSOSGetCapabilities-to-ISO19119_ISO19139
Where am I wrong?
Hints?
Eugenio
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
