[GeoNetwork-users] Problem installing GN v3.2.1 on Tomcat 7
Hi everyone
I'm trying to install GN v3.2.1 war on Tomcat 7.0.28 (Debian 7, Apache 2)
and always get the same problem.
This is report from catalina.out :
INFO: Deploying configuration descriptor
/etc/tomcat7/Catalina/localhost/geonetwork.xml
May 09, 2017 9:30:12 AM org.apache.catalina.startup.HostConfig
deployDescriptor
WARNING: A docBase /var/lib/tomcat7/webapps/geonetwork inside the host
appBase has been specified, and will be ignored
May 09, 2017 9:30:15 AM org.apache.catalina.loader.WebappClassLoader
validateJarFile
INFO:
validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/geronimo-servlet_3.0_spec-1.0.jar)
- jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class:
javax/servlet/Servlet.class
validateJarFile
INFO:
validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/javax.servlet-api-3.1.0.jar)
validateJarFile
INFO:
validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/jsp-api-2.1-6.1.14.jar)
javax/el/Expression.class
validateJarFile
INFO:
validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/servlet-api-2.5-20081211.jar)
validateJarFile
INFO:
validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/servlet-api-2.5-6.1.14.jar)
May 09, 2017 9:30:16 AM org.apache.catalina.core.StandardContext
listenerStart
SEVERE: Error configuring application listener of class
jeeves.config.springutil.JeevesContextLoaderListener
java.lang.UnsupportedClassVersionError:
jeeves/config/springutil/JeevesContextLoaderListener : Unsupported
major.minor version 52.0 (unable to load class
jeeves.config.springutil.JeevesContextLoaderListener)
  at
org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2927)
  at
org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1171)
  at
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1679)
  at
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1557)
  at
org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:532)
  at
org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:514)
  at
org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:133)
  at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4763)
  at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5321)
  at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
  at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
  at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
  at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:618)
  at
org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:650)
  at
org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1582)
  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
  at java.util.concurrent.FutureTask.run(FutureTask.java:262)
  at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
  at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
  at java.lang.Thread.run(Thread.java:745)
listenerStart
SEVERE: Skipped installing application listeners due to previous error(s)
startInternal
SEVERE: Error listenerStart
startInternal
SEVERE: Context [/geonetwork] startup failed due to previous errors
Any sugestions on my next step to solve this problem?
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-GN-v3-2-1-on-Tomcat-7-tp5319854.html
This is due to the fact that you are using Java 1.7 instead of 1.8
(mandatory since version 3.2 of GeoNetwork). You can probably upgrade to
Java 8 using the backports (true for debian8, but it should also be the
case for debian7 with a little bit of luck).
regards,
-- Pierre
Thank You for your reply.
I'll try to install Java 1.8 and do it all over again.
Ivan
      From: Pierre Mauduit <pierre.mauduit@anonymised.com>
To: IvanST <ivucic@anonymised.com>
Cc: geonetwork-users@lists.sourceforge.net
Sent: Tuesday, May 9, 2017 1:32 PM
Subject: Re: [GeoNetwork-users] Problem installing GN v3.2.1 on Tomcat 7
jeeves/config/springutil/ JeevesContextLoaderListener : Unsupported
jeeves.config.springutil. JeevesContextLoaderListener)
This is due to the fact that you are using Java 1.7 instead of 1.8 (mandatory since version 3.2 of GeoNetwork). You can probably upgrade to Java 8 using the backports (true for debian8, but it should also be the case for debian7 with a little bit of luck).
regards,
-- Pierre
Finally I've installed it on CentOS 7 with Tomcat 7 and OpenJDK 1.8 without
any problems.
Thanks for all the help.
Ivan
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-GN-v3-2-1-on-Tomcat-7-tp5319854p5320167.html
