[GeoNetwork-users] Problem loading resources such as thumbnails (another port, not 8080)
The website address I http : // localhost / geonetwork . But thumbnail
images after they are added to the address , for example,
http://localhost:8080/geonetwork/srv/pol//resources.get?uuid=cb545a86-84a1-4e3b-93b5-185d66d8bbc3&fname=1_s.png
And it does not work , there is no such image.
When you delete a manually in the address " : 8080 " everything is in
order , the image is loading .
Where do I change the configuration to make it work well ?
check the settings probably
http://geonetwork-opensource.org/manuals/trunk/eng/users/administrator-guide/configuring-the-catalog/system-configuration.html#catalog-server
HTH
Francois
2016-06-09 15:51 GMT+02:00 kontakt@anonymised.com <kontakt@anonymised.com>:
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
GeoNetwork-users mailing list
