Hi Mathieu, when you start your node, which schemas are loaded ? You should
have something like
2006-10-20 17:47:22,320 INFO [jeeves.apphand] - Initializing geonetwork...
2006-10-20 17:47:22,320 INFO [jeeves.apphand] - - Search...
2006-10-20 17:47:22,420 INFO [jeeves.apphand] - - Access manager...
2006-10-20 17:47:22,430 INFO [jeeves.apphand] - - Data manager...
2006-10-20 17:47:23,662 INFO [jeeves.apphand] - Adding xml schema :
fgdc-std
2006-10-20 17:47:23,832 INFO [jeeves.apphand] - Adding xml schema :
iso19139
2006-10-20 17:47:23,842 INFO [jeeves.apphand] - Adding xml schema :
dublin-core
2006-10-20 17:47:23,862 INFO [jeeves.apphand] - Adding xml schema :
iso19115
2006-10-20 17:47:23,942 INFO [jeeves.apphand] - - Z39.50...
in your log. Schemas are load from directory web/xml/schemas/ Directory. If
you add new schema in here, they will be loaded at next startup. There's no
link with the db for that I think.
Check that directory first ...
Francois
-----Message d'origine-----
De : geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-
bounces@lists.sourceforge.net] De la part de Mathieu Coudert
Envoyé : vendredi 20 octobre 2006 14:39
À : geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] problem schema list in batch import form
Hi list,
I would like to perform a batch import in my geonetwork but I have a
problem. In fact I have no schema defined or available in my list of schema
in the Batch Import page.
Do I need to defined it somewhere?
I checked my database (postgresql) but I don't really know where shema are
stored?
any help please?
Thanks
Mathieu
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-users mailing list
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
