Hello,
I'm trying to install geonetwork on a Linux/Ubuntu 16.04 server but I have a problem. I can deploy the webapp on tomcat8 without any problem but when I try to start it I get the following error
2018-12-11 13:43:03,575 WARN [jeeves.config.springutil.JeevesApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Adresse déjà utilisée (Bind failed)
2018-12-11 13:43:03,584 FATAL [jeeves.engine] - Raised exception during init
2018-12-11 13:43:03,585 FATAL [jeeves.engine] - Exception : org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Adresse déjà utilisée (Bind failed)
2018-12-11 13:43:03,585 FATAL [jeeves.engine] - Message : Error creating bean with name 'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Adresse déjà utilisée (Bind failed)
2018-12-11 13:43:03,588 FATAL [jeeves.engine] - Stack : org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Adresse déjà utilisée (Bind failed)
About that kind of problem I already read this : http://osgeo-org.1560.x6.nabble.com/tcp-localhost-61616-due-to-java-net-BindException-Address-already-in-use-JVM-Bind-td5375333.html and this : https://github.com/geonetwork/core-geonetwork/issues/1933
The result of the command "sudo fuser -v -n tcp 61616" is :
61616/tcp: tomcat8 2959 F.... java
And when I try to kill this process it kills... tomcat8 !
When I undeploy geonetwork and restart tomcat8, the command fuser return nothing.
So it seems that tcp://localhost/61616 is really used by the geonetwork webapp but it keeps saying that this port is used by another process and refuse to start.
I never had another geonetwork installed on this server before. I tried to change the config.properties file to work with another port (61617) but the problem is the same.
Could someone help me please ?
Nicolas
