[GeoNetwork-users] Problem updating System configuration
Hi List!!!!
When I try to update the System Configuration in GeoNetwork 2.6.0 I
get this error:
Unable to save the system configuration
Error : operation-aborted
Message : Cannot set all values
Class : OperationAbortedEx
The error appears in a modal window on the browser.
Any suggestion about how can I fix the problem???
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
Ph. D. Student at University of Calabria - DEIS
Hi
Please check the log file to see if contains more information. Also check
the migration script you applied with
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/2.4.3-to-2.6.0/
I remember the first file of 2.6.0 installer uploaded to sourceforge didn't
work correctly with migration and was uploaded later a new version.
Jose Garcia
On Wed, Oct 6, 2010 at 4:33 PM, Francesco D'Amore <damore@anonymised.com> wrote:
Hi List!!!!
get this error:
(IIA)
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
GeoNetwork-users mailing list
seems to me like same problem reported few days earlier.
Did you read "System config page issue" where it was said that manually edit the
settings table at db should solve it?
HTH
best regards
Sarah
Von: Francesco D'Amore <damore@anonymised.com>
An: geonetwork-users Users <geonetwork-users@lists.sourceforge.net>
Gesendet: Mittwoch, den 6. Oktober 2010, 16:33:10 Uhr
Betreff: [GeoNetwork-users] Problem updating System configuration
Hi List!!!!
get this error:
Hi Francesco,
See http://osgeo-org.1803224.n2.nabble.com/System-config-page-issue-tp5551302p5551302.html for an explanation of the problem and one way to work round it.
David Herbert
British Antarctic Survey.
-----Original Message-----
From: Francesco D'Amore [mailto:damore@anonymised.com]
Sent: 06 October 2010 15:33
To: geonetwork-users Users
Subject: [GeoNetwork-users] Problem updating System configuration
Hi List!!!!
get this error:
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
It occurs to me that I've suddenly seen this issue posted at least three
times in the past couple of weeks (one of which was myself). I don't
recall having seen it before - has something been done in 2.6.0 that would
cause this "corruption" of the database to happen more regularly? Note
that mine was for RC2.
Jonathan Moules
GIS Developer.
Warwickshire Observatory,
Warwickshire County Council.
01926 412358
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi All!!!
In effect, I used the migration script in order to upgrade my old
2.4.3 data model to 2.6.0.
I used the migration script attached on this mail. Garcia, there is
some problem in this sql file???
If yes, where can I download the right version???
Thank you very much!!!!
2010/10/6 <jonathanmoules@anonymised.com>:
Jonathan Moules
GIS Developer.
01926 412358
In the previous mail I don't attached any sql scrpt....sorry....
This is the script used in order to migrate from the data model 2.4.3
to 2.6.0 in a Postgres database:
ALTER TABLE Settings ALTER COLUMN value TYPE text;
ALTER TABLE Metadata ADD displayorder int;
INSERT INTO Settings VALUES (90,1,'selectionmanager',NULL);
INSERT INTO Settings VALUES (91,90,'maxrecords','1000');
INSERT INTO Settings VALUES (210,1,'localrating',NULL);
INSERT INTO Settings VALUES (211,210,'enable','false');
INSERT INTO Settings VALUES (220,1,'downloadservice',NULL);
INSERT INTO Settings VALUES (221,220,'leave','false');
INSERT INTO Settings VALUES (222,220,'simple','true');
INSERT INTO Settings VALUES (223,220,'withdisclaimer','false');
INSERT INTO Settings VALUES (230,1,'xlinkResolver',NULL);
INSERT INTO Settings VALUES (231,230,'enable','false');
INSERT INTO Settings VALUES (600,1,'indexoptimizer',NULL);
INSERT INTO Settings VALUES (601,600,'enable','true');
INSERT INTO Settings VALUES (602,600,'at',NULL);
INSERT INTO Settings VALUES (603,602,'hour','0');
INSERT INTO Settings VALUES (604,602,'min','0');
INSERT INTO Settings VALUES (605,602,'sec','0');
INSERT INTO Settings VALUES (606,600,'interval',NULL);
INSERT INTO Settings VALUES (607,606,'day','0');
INSERT INTO Settings VALUES (608,606,'hour','24');
INSERT INTO Settings VALUES (609,606,'min','0');
INSERT INTO Settings VALUES (700,1,'oai',NULL);
INSERT INTO Settings VALUES (701,700,'mdmode',1);
INSERT INTO Settings VALUES (702,700,'tokentimeout',3600);
INSERT INTO Settings VALUES (703,700,'cachesize',60);
INSERT INTO Settings VALUES (720,1,'inspire',NULL);
INSERT INTO Settings VALUES (721,720,'enable','false');
UPDATE Settings SET value='2.6.0' WHERE name='version';
UPDATE Settings SET value='0' WHERE name='subVersion';
Any error???
2010/10/6 Francesco D'Amore <damore@anonymised.com>:
Hi All!!!
Jonathan Moules
GIS Developer.
01926 412358
Hi Francesco
I think I get the problem. Probably your database was created with GN 2.4.2
or previous (can you confirm?), then these settings specific from 2.4.3:
INSERT INTO Settings VALUES (200,1,'clickablehyperlinks',NULL);
INSERT INTO Settings VALUES (201,200,'enable','true');
are not in the database (unless you migrated also the db from 2.4.X to 2.4.3
using GAST).
That explains also, i think, why the migration process was not executed
automatically when GN 2.6.0 started the first time.
The migration script doesn't contain these inserts as assumes a database
created by GN 2.4.3. If you add the previous INSERTS should work ok.
Jose García
On Wed, Oct 6, 2010 at 5:59 PM, Francesco D'Amore <damore@anonymised.com> wrote:
Any error???
> Hi All!!!
would
>> Jonathan Moules
>> GIS Developer.
>> 01926 412358
>> _______________________________________________
(IIA)
(IIA)
Yes.......... the databases was created since the version 2.4.2 or
previous...... I forgot this important information....
Sorry...
In any case, i resolved the problem regenerating all Setting table
with the sql inserts presents in the db-create script..... Geonetwork
works fine know.
Thank you for your help!!!!
2010/10/6 jose garcia <josegar74@anonymised.com>:
Hi Francesco
using GAST).
Jose García
Any error???
> Hi All!!!
would
>> Jonathan Moules
>> GIS Developer.
>> 01926 412358
(IIA)
(IIA)
