Hi
I am currently experiencing a problem with MapInfo's CSW search of
Geonetwork the problems seems to be related to the way MapInfo defines
the search bounding box (gml:envelope) in particular the
srsDimensions="2" part.
Here is what I'm getting in my Geonetwork logs
2010-07-15 12:12:35,074 INFO [jeeves.request] - HTML Request (from
192.168.66.116) : /geonetwork/srv/en/csw
2010-07-15 12:12:35,074 DEBUG [jeeves.request] - Method : POST
2010-07-15 12:12:35,074 DEBUG [jeeves.request] - Content type : text/xml
2010-07-15 12:12:35,074 DEBUG [jeeves.request] - Accept : null
2010-07-15 12:12:35,074 DEBUG [jeeves.request] - Session id is
dovt5sfhlz2y
2010-07-15 12:12:35,074 DEBUG [jeeves.request] - Session created for
client : 192.168.66.116
2010-07-15 12:12:35,074 INFO [jeeves.service] - Dispatching : csw
2010-07-15 12:12:35,074 DEBUG [jeeves.service] - -> parameters are :
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
service="CSW" version="2.0.2" resultType="results"
outputSchema="http://www.isotc211.org/2005/gmd" startPosition="1"
maxRecords="25">
<csw:Query typeNames="csw:Record gmd:MD_Metadata">
<csw:ElementSetName>full</csw:ElementSetName>
<csw:Constraint version="1.1.0">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:BBOX>
<ogc:PropertyName
xmlns:ows="http://www.opengis.net/ows">ows:BoundingBox</ogc:PropertyName
<gml:Envelope xmlns:gml="http://www.opengis.net/gml"
srsName="epsg:4326" srsDimensions="2">
<gml:lowerCorner>-39.6801 -64.0383</gml:lowerCorner>
<gml:upperCorner>163.079 66.1983</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
2010-07-15 12:12:35,074 INFO [jeeves.webapp.csw] - Received:
maxRecords="25">
<ogc:BBOX>
<ogc:PropertyName
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Lucene Query:
_isTemplate:n
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Lucene Query: +*:*
+_isTemplate:n
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Sorting by :
[relevance,true]
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Getting parser
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Getting feature
source
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Getting index
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Creating filter
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Filter string is :
<ogc:BBOX>
<ogc:PropertyName
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
2010-07-15 12:12:35,084 DEBUG [geonetwork.search] - Parsing filter
2010-07-15 12:12:35,204 ERROR [geonetwork.search] - Errors occurred when
trying to parse a filter:
org.xml.sax.SAXParseException: cvc-complex-type.3.2.2: Attribute
'srsDimensions' is not allowed to appear in element 'gml:Envelope'.
2010-07-15 12:12:35,204 DEBUG [geonetwork.search] - Reprojected Filter
is [ the_geom bbox POLYGON ((-64.0383 -39.6801, -64.0383 163.079,
66.1983 163.079, 66.1983 -39.6801, -64.0383 -39.6801)) ]
2010-07-15 12:12:35,204 DEBUG [geonetwork.search] - Filter Envelope is
ReferencedEnvelope[-64.0383 : 66.1983, -39.6801 : 163.079]
2010-07-15 12:12:35,204 DEBUG [geonetwork.search] - Setting up the TFC
with numHits 26
2010-07-15 12:12:35,214 INFO [jeeves.service] - -> dispatching to
output for : csw
2010-07-15 12:12:35,214 INFO [jeeves.service] - -> writing xml for
: csw
2010-07-15 12:12:35,214 DEBUG [jeeves.service] - Service xml is :
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd">
<csw:SearchStatus timestamp="2010-07-15T12:12:35" />
<csw:SearchResults numberOfRecordsMatched="0"
numberOfRecordsReturned="0" elementSet="full" nextRecord="0" />
</csw:GetRecordsResponse>
2010-07-15 12:12:35,224 INFO [jeeves.service] - -> output ended for
: csw
2010-07-15 12:12:35,224 INFO [jeeves.service] - -> dispatch ended for
: csw
Now if I send a simple request like
2010-07-15 12:14:10,619 DEBUG [jeeves.service] - -> parameters are :
<GetRecords xmlns="http://www.opengis.net/cat/csw/2.0.2"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" service="CSW"
version="2.0.2" maxRecords="10" startPosition="1" resultType="results"
outputFormat="application/xml"
../../../csw/2.0.2/CSW-discovery.xsd">
<Query typeNames="csw:Record">
<ElementSetName typeNames="csw:Record">full</ElementSetName>
<Constraint version="1.1.0">
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>ows:BoundingBox</ogc:PropertyName>
<gml:Envelope>
<gml:lowerCorner>146.096191 -43.897892</gml:lowerCorner>
<gml:upperCorner>148.73291 -42.326062</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</Constraint>
</Query>
</GetRecords>
2010-07-15 12:14:10,619 INFO [jeeves.webapp.csw] - Received:
<ogc:Filter>
<ogc:BBOX>
<gml:Envelope>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</Constraint>
</Query>
</GetRecords>
Geonetwork gives me the correct results that I would expect
Has anyone come across this problem or know how I might fix it?
Duri Bradshaw
GIS Officer
Insight GIS
www.insightgis.com.au <http://www.insightgis.com.au/>
