[GeoNetwork-users] Problem when saving a metadata
Dear all,
This small message to ask you a question regarding GeoNetwork 2.4.1 (using tomcat and postgresql).
I've easily installed and customized the application but I have a problem when I create a new metadata.
I've chosen the ISO19139 vector template, filled all the necessary fields but when I click on save, I have the following message:
"THE REQUESTED OPERATION COULD NOT BE PERFORMED.
IllegalStateException : Element not found at ref ="
I've tried with the other template but I have the same problem.
Does anyone has an idea to solve this issue?
Thank a lot for your help and support.
Greg
Gregory Giuliani
Spatial Data Infrastructure
UNEP/DEWA/GRID-Europe
11, chemin des Anémones
CH - 1219 CHATELAINE
Phone: (+41 22) 917 84 17
Fax: (+41 22) 917 80 29
Web: http://www.grid.unep.ch
Dear all,
Just to inform you that I've found the solution of the problem.
This is an issue due to the Safari browser. I've tested the application on Firefox and everything works fine :slight_smile:
All the best
Greg
On Sep 24, 2009, at 11:31 AM, Gregory Giuliani wrote:
Dear all,
Greg
Gregory Giuliani
Gregory Giuliani
hi Gregory and everyone,
this is interesting. Did anyone else notice this ? Then we should really
look into it, I think.
I don't think GeoNetwork states which browsers it supposedly supports, but
Safari is common enough for us to want to support it, what with everybody's
iPhone and such. Which version of Safari are you using, on which OS ?
Kind regards
Heikki Doeleman
On Fri, Sep 25, 2009 at 9:53 AM, Gregory Giuliani <giuliani@anonymised.com>wrote:
Dear all,
All the best
Greg
> Dear all,
> Greg
> Gregory Giuliani
Gregory Giuliani
Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
http://p.sf.net/sfu/devconf
GeoNetwork-users mailing list
Hi Heikki,
I was also really surprised to find that this issue is "probably linked" to browsers, especially due to the fact that Safari is quite common now.
I used Safari 4.0.3 on MacOS 10.5.8
I've just tested on my iPhone, with Safari Mobile and I've raised the same issue...
Hope this could help you :slight_smile:
Regards
Greg
this is interesting. Did anyone else notice this ? Then we should really look into it, I think.
I don't think GeoNetwork states which browsers it supposedly supports, but Safari is common enough for us to want to support it, what with everybody's iPhone and such. Which version of Safari are you using, on which OS ?
Kind regards
Heikki Doeleman
On Fri, Sep 25, 2009 at 9:53 AM, Gregory Giuliani <giuliani@anonymised.com> wrote:
Dear all,
All the best
Greg
> Dear all,
> Greg
> Gregory Giuliani
Gregory Giuliani
Gregory Giuliani
