[GeoNetwork-users] problem with adding new fields to metadata default view
Hi friends,
I want to add some new fields like "supplementalInformation", "useConstraints" and "accessConstraints" to metadata default view. For adding supplementalInformation I followed instructions according to this link:
https://gis.stackexchange.com/questions/202539/change-geonetwork-default-metadata-view.
However it does not work. I use <div data-ng-if="mdView.current.record.supplementalInformation">, but the code does not enter to this div even for a metadata that I am sure it has supplemental information(by looking at XML view). I also cleared formatter and js caches and restarted tomcat.
For adding useConstraints and accessConstraints, I don't know what to do. I also have a metadata which includes these constraints but they are not shown in metadata default view.
Any help please?
Best,
Samin
Hi Samin
Just to be sure, did you reindex the catalogue, adding a new field in the
index requires a reindex, otherwise the new fields are not added.
Jose García
On Tue, Aug 29, 2017 at 3:01 PM, Samin Payrosangari <s6sapayr@anonymised.com>
wrote:
Hi friends,
link:
Any help please?
Best,
Samin
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Hi Jose,
Actually, reindexing is in progress for a long time. I did not know that it is important for adding fields. So I should be waiting until it finishes to see the result.
What about accessConstraints and useConstraints? How should I activate them? For example in this metadata https://wascal-dataportal.org/geonetwork/apps/search/?uuid=43b49387-97b8-4231-b3f2-ad2a3fe54d0f , that I harvested from wascal geoportal, there are several constraints, but my portal only displays other constraints and calls them legal constraints.
When I look at the code in default.xsl, it seems that they are part of the resourceConstraints which is already included in recordView.html. But why my portal does not show them(I have geonetwork 3.2).
Best,
Samin
   On Tue, 29 Aug 2017 15:13:02 +0200
  Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Samin
Jose García
wrote:
Hi friends,
link:
Any help please?
Best,
Samin
s/geonetwork
Dear Jose,
I rebuilt index. Still nothing appears for supplementalInformation :(.
Best,
Samin
On Tue, 29 Aug 2017 15:24:00 +0200
  "Samin Payrosangari" <s6sapayr@anonymised.com> wrote:
Hi Jose,
Best,
Samin
Hi Samin
Jose García
wrote:
Hi friends,
link:
Any help please?
Best,
Samin
s/geonetwork
Hi Samin
I'll check to test locally tomorrow to see what can be missing.
Jose García
On Tue, Aug 29, 2017 at 3:28 PM, Samin Payrosangari <s6sapayr@anonymised.com>
wrote:
Dear Jose,
Best,
Samin
Hi Jose,
to see the result.
Best,
Samin
Hi Samin
Jose García
wrote:
Hi friends,
link:
sure
do.
Any help please?
Best,
Samin
s/geonetwork
+31
Hi Jose,
Thanks, I'll be waiting for you.
Best,
Samin
On Tue, 29 Aug 2017 17:36:48 +0200
Hi Samin
Jose García
wrote:
Dear Jose,
Best,
Samin
Hi Jose,
to see the result.
Best,
Samin
Hi Samin
Jose García
wrote:
Hi friends,
link:
sure
do.
Any help please?
Best,
Samin
s/geonetwork
+31
Hi Samin
I have done these steps (similar to the ones described in
work-default-metadata-view.). Please check with your changes (tested with
3.2.x branch):
1) Assuming the paths from the deployed war file (highlighted the changes),
update the following files:
*$TOMCAT_DIR/geonetwork/WEB-INF/config-lucene.xml*
      <field name="_groupWebsite" tagName="groupWebsite"/>
      <field name="attributeTable" tagName="attributeTable"/>
    * <field name="supplementalInformation"
tagName="supplementalInformation"/>*
    </dumpFields>
  </search>
*$TOMCAT_DIR/geonetwork/WEB-INF/data/config/schema_plugins/iso19139/index-fields/default.xsl*
     * <xsl:for-each
select="gmd:supplementalInformation/gco:CharacterString">*
* <Field name="supplementalInformation" string="{string(.)}"
store="true" index="true"/>*
* </xsl:for-each>*
      <xsl:for-each select="gmd:topicCategory/gmd:MD_TopicCategoryCode">
        <Field name="topicCat" string="{string(.)}" store="true"
index="true"/>
        <Field name="keyword"
string="{util:getCodelistTranslation('gmd:MD_TopicCategoryCode',
string(.), string($isoLangId))}"
      </xsl:for-each>
*$TOMCAT_DIR/geonetwork/*
*/catalog/views/default/templates/recordView.html*
        <h2 data-translate="">aboutThisResource</h2>
        <table class="table table-striped">
          <tbody>
          <tr data-ng-if="mdView.current.record.supplementalInformation">
            <th data-translate="">supplementalInfo</th>
            <td>
              <p
data-ng-bind-html="mdView.current.record.supplementalInformation |
newlines">
                </p>
            </td>
          </tr>
          <tr data-ng-if="mdView.current.record.inspirethemewithac.length >
0 ||
0">
            <th data-translate="">inspireThemes</th>
2) After these changes startup Geonetwork and re-index the catalogue from
the Administration panel. (
http://SERVER/geonetwork/srv/eng/admin.console?debug#/tools)
3) From same option cleanup JS&CSS cache.
4) Import a metadata with supplemental information, like
5) Search for the metadata and display the metadata detail page. I get the
following:
About this resource
supplementalInfo
Codes were assigned so that each variable can directly be linked to the
corresponding question in the questionnaire.
The code is generated on the basis of the section number (I), number of
question (1,2,3,...) and subcategories of each question (x.1, x.2, x.3,...
or A,B,C,...)
Please compare with questionnaire file.
Categories Interactive resources Farming
Keywords
   - household <http://localhost:8080/geonetwork/srv/eng/catalog.search?&gt;
   - farmers <http://localhost:8080/geonetwork/srv/eng/catalog.search?&gt;
Jose García
On Wed, Aug 30, 2017 at 11:16 AM, Samin Payrosangari <s6sapayr@anonymised.com>
wrote:
Hi Jose,
Best,
Samin
Hi Samin
Jose García
wrote:
Dear Jose,
Best,
Samin
Hi Jose,
finishes
to see the result.
that
But
Best,
Samin
Hi Samin
the
Jose García
wrote:
Hi friends,
this
link:
sure
cleared
do.
not
Any help please?
Best,
Samin
s/geonetwork
+31
+31
Hi Jose,
Thanks, its working. I think the problem was which part of default.xsl to enter the code.
should I do the same for adding access constraints and use constraints which are also included in the same metadata I sent you for testing? According to the source code, I've done something but I don not know if its right.
Best,
Samin
Best,
Samin
On Wed, 30 Aug 2017 21:25:21 +0200
Hi Samin
3.2.x branch):
   </dumpFields>
</search>
    * <xsl:for-each
* </xsl:for-each>*
index="true"/>
     </xsl:for-each>
         <tbody>
           <td>
             <p
newlines">
               </p>
           </td>
         </tr>
0 ||
0">
following:
About this resource
supplementalInfo
or A,B,C,...)
Keywords
Jose García
wrote:
Hi Jose,
Best,
Samin
Hi Samin
Jose García
wrote:
Dear Jose,
Best,
Samin
Hi Jose,
finishes
to see the result.
that
But
Best,
Samin
Hi Samin
the
Jose García
wrote:
Hi friends,
this
link:
sure
cleared
do.
not
Any help please?
Best,
Samin
s/geonetwork
+31
+31
